Crown Boiler Closed System Baseboard Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-03-2010, 08:02 PM   #1
Crown Boiler closed system baseboard heat
I have a crown boiler with summer/winter hookup. It is a closed baseboard heat system, that is to say I do NOT have bleeder valves anywhere on or behind any baseboard cover. All I have is a pressure valve to allow water into the system should it drop below a certain psi level and a drain just below the circulating pump coming off the bottom of the boiler. I have been releasing water from the system in increments and refilling with the pressure valve in different combos and stages. I have managed to get heat upstairs when I add water to the system to the psi level of 30 to 40 psi. But, the system does not circulate and I can hear gurgling upstairs on the return end of the closed circuit of copper pipes. Any thoughts on how to get this air out so the circulating pump will do it's job? Thanks.
chefscott67 is offline   Reply With Quote
Old 11-03-2010, 08:38 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Time to get bleeders installed. There should atleat be a bleed at the boiler.
Also, 30-40 psi is way to high. The pressure reducing valve should regulate the water pressure to 12 psi
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 11-04-2010, 05:02 AM   #3
An old Tradesmen
Rewards Points: 6,900
Post pics of the piping near the boiler. You probably have a purge valve set up. But you don't recognize it for what it is. Might even have it above the boiler if the return piping comes back from 2 or more directions.
They had to have a way to get rid of the air when they first installed the system.
Old 11-04-2010, 06:54 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,056
I would think there should be a pressure relief valve on the boiler that should Blow Off at 30psi....
I agree with Plumber,... I'd cut in a few bleeds at some high points...
Bondo is online now   Reply With Quote
Old 11-04-2010, 08:43 PM   #5
An old Tradesmen
Some boilrsr come with a 50 PSIG relief valve.
baseboard heat cover SteveBman Remodeling 2 02-02-2010 07:00 AM
Which heatings system should I go with? keano016 HVAC 5 12-01-2009 02:53 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 01:11 PM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 05:47 PM
