Creating Additional "sleeves" In Sheet Metal? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-23-2012, 02:17 PM   #1
Creating additional "sleeves" in sheet metal?
First time poster, asking for some assistance in knowing what to call the "sleeves" that hold the makeshift door in place in these photos.
Basically, I want to extend the "sleeves" upward as I plan on cutting the hole larger to accomodate a 25" high filter (as you can see from the photos, I'm having to bend a 25" to fit, which ends up mangling it).
The installers called for a 20" filter, but that's slightly too short in this setup. I'm wondering if those metal strips have a specific name that I can ask for at my local hardware store.
Also wondering if I should consider some sort of frame on which to rest the filter. I'm having to duct tape the top in place.
Thanks in advance!
Creating additional "sleeves" in sheet metal?-img_1560.jpg   Creating additional "sleeves" in sheet metal?-img_1561.jpg
SteveJenkins is offline   Reply With Quote
Old 12-23-2012, 02:30 PM   #2
Nevermind... after further inspection, it's just sheet metal that's bent, screwed in place, then bent again. So that part, I can handle. Still wondering what my options are for frames, however. Any advice is appreciated.
Old 12-23-2012, 02:42 PM   #3
Roofmaster
Rewards Points: 2,210
They are called "Drives" You bend a return hen on the ductwork and "drive" the Drives into place, leaving about an inch overhang on both ends then bending tabs down. The drives are basically sheet metal broken into a tight "C"
Old 12-23-2012, 02:45 PM   #4
Rewards Points: 616
looks like s-cleat to me...call it a drive if you want to.....
carmon is offline   Reply With Quote
Old 12-23-2012, 03:04 PM   #5
Those are definitely ess cleats (shaped like an 's'). It's hard to tell from your pictures, but could you put a 4" filter frame in place of the box to the right of the return drop?
hvac benny is offline   Reply With Quote
The Following User Says Thank You to hvac benny For This Useful Post:
beenthere (12-23-2012)
Best place to buy sheet metal and lumber? jk333 Building & Construction 6 02-25-2009 09:22 AM
Cutting in Bubbagump Painting 21 11-04-2008 09:23 PM
Tape vs. Sheet metal screws alvanos HVAC 7 03-25-2008 01:26 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
Attaching Roof to side of home joe3534 Roofing/Siding 1 04-29-2007 09:54 PM
