Crawlspace Dehumidifier Control - HVAC - DIY Chatroom Home Improvement Forum
Old 07-20-2013, 08:14 AM   #1
I an replacing a worn out crawlspace dehumidifier. I would like to be able to remotely monitor and control the unit from the living space.
I was considering the Honeywell DR65 dehumidifier and the TrueIAQ humidistat, and was going to put the outdoor sensor in the crawlspace...then I realized I was a fool, as the TrueIAQ in the living area would not be sensing the conditions in the crawlspace, but rather in the living area where it was installed.
Does anyone here have a solution to how I might be able to accomplish this?
RoyalAcresRod is offline   Reply With Quote
Old 07-20-2013, 08:29 AM   #2
Rewards Points: 20
You could get an internet connected thermostat that also controls humidity and put it in the crawlspace. You would be able to monitor it via web or smartphone. The Honeywell Total Comfort app is pretty good.
Dan
djlandkpl is offline   Reply With Quote
Old 07-20-2013, 08:32 AM   #3
Thank you. I hadn't considered that route !
Turn thermostat to COOL (mobile home split system), fuse on control board blows. justplumducky HVAC 8 04-29-2013 07:42 PM
Consumer Dehumidifier for 1000 sq ft encapsulated crawlspace? chazman113 HVAC 4 08-11-2011 08:57 AM
Questions about sealing a crawlspace. John_W HVAC 5 07-11-2010 02:24 PM
Ceiling Fan Speed Control czars HVAC 0 01-14-2010 08:06 PM
