Old 12-02-2012, 03:14 PM   #1
Crawl space insulation
Purchasing a home in Savannah GA. It has a crawl space over dry dirt probably 2 ft space in terms of height off ground.
Sub flooring is insulated but the paper backing is facing the dirt versus the floor above. So with this incorrect installation of insulation, what is the best way to fix it. Remove a flip it over, replace with new insulation with paper against the sub floor, or just leave it.
Someone told me to leave it in place and cut vents in the paper?
Need some good advice. Thks
Rundle is offline   Reply With Quote
Old 12-02-2012, 06:07 PM   #2
An old Tradesmen
Leave it as is.
Low crawl space Insulation mhahn Insulation 1 10-01-2012 09:40 AM
Crawl space insulation questions Gates Building & Construction 3 01-26-2011 09:57 AM
crawl space insulation thevoz Building & Construction 6 01-10-2010 12:56 AM
Unvented crawl space insulation ehardman Building & Construction 3 01-13-2009 01:44 PM
Crawl space insulation howard.wheaton Building & Construction 10 10-21-2008 10:41 PM
