Crankcase Oil Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 09:35 AM   #1
Crankcase oil heater
Is this a neccessary item for a heat pump in Alabama?
The Trane heat pump in my home has one, the electrical wire going to it got old, brittle and water seep in to the wiring ausing it to burn the wire into. I can find the part but am hearing different stories that it is and is not needed.
Any ideas?
Tommy D is offline   Reply With Quote
Old 11-28-2012, 09:56 AM   #2
Items wanted: Time
Rewards Points: 150
Yes it is needed, when the outdoor temp is lower than indoor temp the refrigerant will migrate to the outdoor unit in off periods. Then when started your cimpressor will slug liquid, this will shorten life if not ruin it immediately.
NiNe O is offline   Reply With Quote
The Following User Says Thank You to NiNe O For This Useful Post:
hvactech126 (11-29-2012)
Old 11-28-2012, 04:03 PM   #3
An old Tradesmen
Rewards Points: 7,802
Yep, it helps prolong the life of the compressor.
The Following User Says Thank You to beenthere For This Useful Post:
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Trane XL1200 Crankcase Heater dranobob HVAC 2 06-14-2012 03:19 PM
Trane XE1200 crankcase heater jdsimpkins HVAC 16 05-21-2012 04:47 PM
Question on Carrier Crankcase Heater Larry H HVAC 8 12-11-2011 12:24 AM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
