Craigslist Shop Heater Won't Fire Up. - HVAC - DIY Chatroom Home Improvement Forum
Old 11-23-2012, 12:13 AM   #1
Craigslist shop heater won't fire up.
I'll start off by asking please don't judge, I try to be thrifty and save a little money and sometimes it bites me in the *#%#*! I bought a Lennox LF24-45a-5 propane converted shop heater off of Craigslist to heat my detached garage. Pulled the manual offline and installed per instructed. Used my 5 gal propane tank(full) from my BBQ for a test run and no flame. I ran through at least 9 cycles where I could hear the igniter and the blower working but no flame. The LED flashes twice indicating no gas. Before the install i cleaned with compressed air. The next step was out of pure desperation, and please don't judge. Against all warning labels telling me not to light it myself, I got my thickest leather gloves and a fire extinguisher and tried to light it. All I got out of the jets were a small blue flame. Any advise would be greatly appreciated! Thanks
Steve
agna is offline   Reply With Quote
Old 11-23-2012, 04:35 AM   #2
An old Tradesmen
Rewards Points: 8,144
Did you have a regulator on the gas line from your BBQ tank. If not, may have damaged the gas valve. Tank pressure is too high for the gas valve to work.
The Following 3 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (11-23-2012), oh'mike (11-23-2012), user1007 (11-23-2012)
Old 11-23-2012, 09:23 AM   #3
Ugh!! No regulator. Makes sense now that I think about it. Hope I didn't destroy my valve. I'll try a hose with a regulator tomorrow. If not ill be back on this site soliciting help on replacing my gas valve. Thanks for your insight!!
Steve
Old 11-23-2012, 11:59 AM   #4
Craig's List?
What's to judge?????
J/K guy.
You'll get all the help you need here.
hvac5646 is offline   Reply With Quote
Old 11-23-2012, 03:40 PM   #5
An old Tradesmen
Steve
If you use a regular reg like the one on a BBQ grille. Your flame may still be small, as those regs knock the pressure down to hat the manifold should be.
Old 11-23-2012, 03:59 PM   #6
I'll be headed to my local rv shop to pick up a regulator and hose. Looks like those are rated up to 160k btu. That is if I didn't fry my gas valve. ill update tomorrow, for now..fingers crossed
Steve
The Following User Says Thank You to agna For This Useful Post:
Old 11-24-2012, 01:43 PM   #7
Now my neighbors think I'm crazy. With the regulator hooked up and everything checked twice over I turned it on and woof! It fired right up!! I jumped and yelled woooohoo!! Went outside and my neighbors were looking at me. A "warm" thanks to all that helped!
Steve.
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 09:12 PM
Electrical Fire seansy59 Electrical 1 10-24-2011 05:57 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 04:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
