Crack In Inducer Motor Housing - HVAC - DIY Chatroom Home Improvement Forum
Old 10-05-2010, 01:00 PM   #1
Crack in Inducer Motor Housing
My gas company shut off and sealed the gas supply to my furnace because there is a crack in the Inducer Motor Housing of my furnace (Zephyr brand, 80% AFUE). I want to know if I can use Epoxy Putty to fix this crack. After I apply Epoxy Putty to the crack, how can I restore the gas supply. Help Please, Thanks a lot in advance
Newer is offline   Reply With Quote
Old 10-05-2010, 03:32 PM   #2
If the gas company put a lock on the gas main I believe you have to call them to unlock it. Did they leave a number to call on their tag?
You better ask them if you epoxy it will they accept it.
Artco is offline   Reply With Quote
The Following User Says Thank You to Artco For This Useful Post:
Newer (10-06-2010)
Old 10-05-2010, 05:27 PM   #3
An old Tradesmen
Rewards Points: 6,596
Doubt they'll accept an epoxy repair.
You need to replace the inducer. And then call the gas company to check it and restore your gas service.
The Following User Says Thank You to beenthere For This Useful Post:
Newer (10-06-2010)
Inducer installation / modification ... caseywa HVAC 26 12-06-2010 02:50 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 10:39 AM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 01:59 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
Heil furnace inducer vibrating, capcitor handling question diggerdave HVAC 45 03-01-2009 05:56 PM
