Old 07-28-2010, 06:19 PM   #1
iya
CPH - how does it work?
From a previous thread I posted, it was recommended I switch my old mercury for a digital 'stat. This I did, and I set the cooling CPH to 2. I guess the question is - how does the CPH really work? I have the honeywell RT2310B, which I don't think has that "auto learn" feature some other stats do.. so does that mean I'm supposed to get 2 cycles per hour max? Approximately 2 cycles per hour? Is it normal to get about 4 cycles anyway (I'm supposing this is possible), depending on outside temps and insulation?
iya is offline   Reply With Quote
Old 07-28-2010, 08:07 PM   #2
An old Tradesmen
CPH. is based on a 50% load.
That is the only time, that you should definitely get 2 CPH. As the outdoor temp increases or decreases(depending on season). The CPH your actually getting will increase or decreae.
On Honeywell thermostats, temp overides CPH.
Issues w/ Old Work Box mkrawitz Electrical 5 04-19-2010 12:53 PM
Dimmer didn't work, now old light switches don't work properly townpump Electrical 9 03-16-2008 08:28 PM
Hiring guys to do work without a contractor Safe or Not Worth Liability wise? twilightcall General Discussion 1 03-15-2008 09:40 PM
Need help with permit/city got a Stop Work Order. amdspitfire General Discussion 39 02-07-2008 03:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 07:09 PM
