-   -   CPH - how does it work? (http://www.diychatroom.com/f17/cph-how-does-work-77386/)
iya 07-28-2010 05:19 PM
From a previous thread I posted, it was recommended I switch my old mercury for a digital 'stat. This I did, and I set the cooling CPH to 2. I guess the question is - how does the CPH really work? I have the honeywell RT2310B, which I don't think has that "auto learn" feature some other stats do.. so does that mean I'm supposed to get 2 cycles per hour max? Approximately 2 cycles per hour? Is it normal to get about 4 cycles anyway (I'm supposing this is possible), depending on outside temps and insulation?
beenthere 07-28-2010 07:07 PM
CPH. is based on a 50% load.
That is the only time, that you should definitely get 2 CPH. As the outdoor temp increases or decreases(depending on season). The CPH your actually getting will increase or decreae.
On Honeywell thermostats, temp overides CPH.
