CPH - Compressor Cycle Rate - HVAC - DIY Chatroom Home Improvement Forum
Old 02-28-2011, 08:03 PM   #1
Rewards Points: 12
I understand that setting the thermostat CPH to 3, yields 3 10 minute on/10 minute off cycles per hour.
My heat pump has a 2 stage compressor and the thermostat has CPH control for both stages. Why would you set Stage 1 to a different CPH from the Stage 2 compressor?
OscarNelsen is offline   Reply With Quote
Old 02-28-2011, 08:34 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
you would not.... both should be cph of 3
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-28-2011, 10:05 PM   #3
Rewards Points: 12
Thanks for your response. I have no intention of changing these settings, but want to learn. I have installed a couple of programmables, but never on a 2 stage system. Why are there separate CPH controls for the compressor stages?
Old 03-01-2011, 05:29 AM   #4
An old Tradesmen
Rewards Points: 6,074
Because it changes how tight the temp control is. Some people like the system to shut off even at higher outdoor temps. Some people prefer the greater comfort of a unit that is running longer during the mid to 80% of design condition temp days of the summer.
A CPH setting of 3 doesn't mean it will run 3 10 minute on 10 minute off cycles per hour all the time. That is just what it will attemp and is only accurate at 50% load.
The Following User Says Thank You to beenthere For This Useful Post:
OscarNelsen (03-01-2011)
Old 03-01-2011, 09:01 AM   #5
Rewards Points: 12
Thanks. I realize that what I am learnig most is the less I know.
Old 03-01-2011, 04:25 PM   #6
An old Tradesmen
We all learn that there is always more to learn.
Bobcat Going rate question Joe1. Off Topic 0 09-07-2010 02:42 PM
Natural Gas "Flow Rate Check"? BSYarg General DIY Discussions 4 08-13-2010 07:22 PM
Drop Rate on Scott's Drop Spreader SPS-1 Landscaping & Lawn Care 1 04-28-2009 09:24 PM
going rate of tile laying samiller1980 Flooring 2 12-03-2008 05:03 PM
Whats the going rate for a FULL cement truck? 6/2008 price? ehoez Building & Construction 15 06-18-2008 01:32 PM
