-   -   CPH - Compressor Cycle Rate (http://www.diychatroom.com/f17/cph-compressor-cycle-rate-96860/)
OscarNelsen 02-28-2011 07:03 PM
I understand that setting the thermostat CPH to 3, yields 3 10 minute on/10 minute off cycles per hour.
My heat pump has a 2 stage compressor and the thermostat has CPH control for both stages. Why would you set Stage 1 to a different CPH from the Stage 2 compressor?
hvactech126 02-28-2011 07:34 PM
you would not.... both should be cph of 3
OscarNelsen 02-28-2011 09:05 PM
Thanks for your response. I have no intention of changing these settings, but want to learn. I have installed a couple of programmables, but never on a 2 stage system. Why are there separate CPH controls for the compressor stages?
beenthere 03-01-2011 04:29 AM
Because it changes how tight the temp control is. Some people like the system to shut off even at higher outdoor temps. Some people prefer the greater comfort of a unit that is running longer during the mid to 80% of design condition temp days of the summer.
A CPH setting of 3 doesn't mean it will run 3 10 minute on 10 minute off cycles per hour all the time. That is just what it will attemp and is only accurate at 50% load.
OscarNelsen 03-01-2011 08:01 AM
Thanks. I realize that what I am learnig most is the less I know.
beenthere 03-01-2011 03:25 PM
We all learn that there is always more to learn.
