Covering A Furnace Outlet Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 10-20-2010, 09:15 AM   #1
vsf
Covering a furnace outlet duct
Just had new furnace installed with venting through duct to outside; can I put a screen over it to prevent anything getting into the duct but allowing air flow?
thank you
vsf is offline   Reply With Quote
Old 10-20-2010, 09:52 AM   #2
Chicago, IL
Michael Thomas's Avatar
B-Vent? PVC? Something else?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 10-22-2010, 11:44 AM   #3
vsf
covering a furnace outlet duct
The duct is 3" (I think) standard PCV Pipe....I'm just concerned about mice or whatever getting up into pipe & house but probably shouldn't cover the duct opening?
Thanks in advance!
Old 10-22-2010, 12:01 PM   #4
fabrk8r
fabrk8r's Avatar
That pipe is likely to be the exhaust vent for your furnace. Are there two pipes or just one? Can you follow it back to your furnace to be sure?
If there are two, one is combustion air and one is exhaust. Not recommended to cover with wire mesh due to possibility of freezing in cold temps when furnace is running. I've never had a problem with critters getting into the exhaust vent, but children and golf balls can be a nuisance. Some people cover the vents in warm weather to keep birds and bees out, but it's not a good idea during heating season.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 10-22-2010, 12:12 PM   #5
vsf
Only 1 PVC Pipe and believe it is exhaust. Your comment sounds good and answers my question: will consider putting something over it during summer.
I very much appreciate your help.
Old 10-22-2010, 01:54 PM   #6
Rewards Points: 292
I once had a bird feeder which the squirrels would continually raid (climb up the pole). Greased the pole. That was the end of that.
V
veesubotee is offline   Reply With Quote
Old 10-22-2010, 02:09 PM   #7
vsf
Thank you - that's good advise - for my duct & feeder both!
Old 10-22-2010, 08:35 PM   #8
Rewards Points: 159
I put some of that soft aluminum gutter guard over my 3" PVC exhaust. The holes are small enough to keep the critters out but doesn't obstruct the exhaust flow very much. I got the material from Home Depot. It has been on for more than ten years with no problems. I also drilled a small hole in the bottom of the PVC pipe where it exits the wall so that condensate can drain onto the ground and not accumulate on the inside of the pipe. No icing or any other problems encountered and no critters. Hope this helps.
kb3ca is offline   Reply With Quote
The Following User Says Thank You to kb3ca For This Useful Post:
vsf (10-25-2010)
Old 10-23-2010, 08:58 AM   #9
Electrician
SD515's Avatar
Rewards Points: 504
Do the instruction that came with the furnace mention anything? Some recommend (and even come with) 1/4" mesh screen.
Kyle
Old 10-25-2010, 09:51 AM   #10
vsf
I will look at the instructions (had not) but the mesh screen was what I had in mind - thanks for the suggestion
Old 10-25-2010, 11:07 AM   #11
fabrk8r
fabrk8r's Avatar
If you put 1/4" wire mesh into or anywhere close to the end of that vent pipe you will most likely have ice build up when the temperature is below freezing since you have a condensing furnace. Ice build up will cause restriction and the furnace will shut down and not light due to back pressure in the vent until the ice is removed.
Why all the concern about covering the vent pipe? Ask any HVAC tech and they will tell you not to worry unless you have children who like to put things into places they don't belong. Animals are smart enough to stay out of confined places which smell like there is a lack of oxygen present.
Old 10-25-2010, 11:36 AM   #12
vsf
cover a furnace duct outlet
Makes sense - I will quit worrying about mice or anything getting up into duct.
thank you
Old 10-25-2010, 11:55 AM   #13
fabrk8r
fabrk8r's Avatar
FWIW, it would be virtually impossible for any varmints to enter your duct through the furnace vent pipe because the combustion chamber is separated from the duct, unless you have a hole in your heat exchanger...in which case you have bigger problems than mice!
Old 10-25-2010, 12:44 PM   #14
vsf
covering a furance outlet duct
I feel better about the duct opening situation now & very much appreciate your comments.....as well as another one that suggested drilling a hole at the bottom of vent to allow moisture to drip out. I will now be able to focus on the next thing for me to stress about
Thanks again
Old 10-25-2010, 12:46 PM   #15
fabrk8r
fabrk8r's Avatar
Don't sweat the petty things...and don't pet the sweaty things. ;o)
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Advice needed. Complete Furnace & duct replacement - asbestos ductwrap (crawl space) vestaviascott HVAC 11 03-10-2009 06:40 PM
Connecting inline duct fan to furnace dlem HVAC 1 02-11-2008 06:50 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
