Covering/Blocking A Baseboard Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 11-20-2009, 08:22 AM   #1
Question
Covering/Blocking a Baseboard Heater
I have a circulating hot water baseboard heater running along a wall in a large room. I want to build a large set of built-in bookcases along half the wall, essentially covering the heater. What are my options?
I am thinking of removing the heater elements and having the pipe run underneath the bookcase, covered with insulation. This will remove the heating ability of the heater, but I think the room will be fine because it has another on the other side. Is this safe and up to code to do this?
If not, is it feasible to reroute it to the front base of the bookcase?
Thanks,
Jeff
jjorczak is offline   Reply With Quote
Tags
baseboard , blocking , heater , radiator , water
Baseboard heater under window jhubert Electrical 1 10-07-2009 11:59 PM
fan / baseboard heater question deepstuff Electrical 6 10-03-2009 03:09 PM
wiring a 240V baseboard heater 777 Electrical 10 05-17-2009 11:47 AM
Baseboard Heater: Can I wire it to plug into an AC recepticle? JBiz Electrical 3 12-01-2007 09:42 AM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
