Cover For Outside Ac Fan/compressor? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-19-2013, 03:31 PM   #1
bryanp22's Avatar
Rewards Points: 300
Cover for outside ac fan/compressor?
I am not sure exactly what the outside portion of my ac is called. Is it a fan or compressor portion? Anyway I have a older carrier ac unit and it didn't come with a cover when I bought the house but how important is it to cover it? Hasn't affected it so far it seems. It's just starting to rust on the grates is all.
bryanp22 is offline   Reply With Quote
Old 10-19-2013, 03:33 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
it is called the condenser.
no need to cover it unless you get more than 1 foot of snow on top of it. they are designed to run in the rain and are weatherproof. Cheap blue tarp from HDepot if it makes U feel better.
The Following 3 Users Say Thank You to yuri For This Useful Post:
ben's plumbing (10-19-2013), COLDIRON (10-20-2013), old_squid (10-20-2013)
Old 10-19-2013, 06:49 PM   #3
Experienced HVAC Tech
HVAC1000's Avatar
My dad always told me that it is ok to cover the top and part way down the sides but not the entire thing because it can then trap moisture inside and cause more corrosion at an accelerated rate. Not sure if that is true or not but I've always told customers to put some OSB or Ply Wood over the top to prevent leaves and other crud from getting in then roll up your garden hose and store on top of wood to weigh it down. And if they are really concerned they can wrap something like a blue tarp around it but leave the bottom 9to 12 inches exposed.
However I personally only put the wood and hose on top to keep leaves out. Plus it helps me know where the hose is under several feet of snow
HVAC1000 is offline   Reply With Quote
The Following 3 Users Say Thank You to HVAC1000 For This Useful Post:
Old 10-19-2013, 07:52 PM   #4
Rewards Points: 616
a cover causes more harm than good... put a piece of plywood on it and a rock to hold plywood down.... seen lots of corroded ones from moisture if cover does not get removed in time....
carmon is offline   Reply With Quote
The Following 4 Users Say Thank You to carmon For This Useful Post:
ben's plumbing (10-19-2013), COLDIRON (10-20-2013), joecaption (10-19-2013), old_squid (10-20-2013)
Attaching patio cover to the top of cinder block wall robertwallace Building & Construction 7 07-10-2012 10:22 PM
Cover modification for older Murray service panel JeffT Electrical 2 05-29-2012 10:43 PM
HELP for simple patio and patio cover 1st time crzysprstr Building & Construction 8 05-29-2012 10:00 PM
removing wall vent cover help numpty HVAC 4 05-03-2012 07:00 AM
Floor Drain Cover - Advice? globus999 Plumbing 2 07-23-2010 10:40 PM
