Old 07-23-2014, 05:11 PM   #1
Share |
cover duck work with 6mm poly?
Can i cover the duct work with plastic and tuck tape? was gonna add a insulation bates.
begal is offline   Reply With Quote
Old 07-23-2014, 05:24 PM   #2
Guess you mean batts.
Why are you covering them with plastic?
Duct tape should never be used on ducts, only foil tape and or mastic.
Cheaper and more bang for the buck using blown in insulation.
Need far more info, location, how the roof is vented, how much is there now, how is the roof vented.
Ridge vent, soffit vents, any baffles installed?
Old 07-23-2014, 05:25 PM   #3
Should be OK to do that, but curious why you want to wrap it in plastic.
Bitters is offline   Reply With Quote
Old 07-23-2014, 05:44 PM   #4
To keep the heat in.
Old 07-23-2014, 07:08 PM   #5
Hold in heat where, and why?
A vapor barrier does nothing to hold in heat.
It's to keep out moisture.
Any heat and moisture needs to be vented out of the attic.
Old 07-24-2014, 09:49 AM   #6
I think the poster meant that they want to wrap the vents in batt insulation and then 6mm plastic and duct tape, basically insulating the duct work. I think it would be possible but I know there are actual duct insulation premade for this purpose and their cost v the time and effort should be a wash IMO.
dzl13 is offline   Reply With Quote
Old 07-24-2014, 12:30 PM   #7
All the duct work is in the basement. So lots of damp cold air i don't want in any of the vents.
"Any heat and moisture needs to be vented out of the attic."
I have a warm attic. Are you saying i should cut open the vapor barrier at the top ceiling?
DIY Electrical work in New Jersey electures Electrical 42 12-19-2012 03:19 PM
How many hours to do this work? brainfogbetty Drywall & Plaster 17 10-26-2011 04:17 AM
New work vs Old work Tetranitrate Electrical 3 07-12-2011 08:19 AM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 10:23 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
