Cover 2nd Floor Ceiling Height Air Returns In Heating Season?? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 01:22 PM   #1
Rewards Points: 2,516
Two floor house with an unfinished basement.
Have a Goodman-single stage - natural gas - forced air - 100K BTU furnace.
Air returns on 1st floor are at floor level. I have five(5) 16" v 10" ones.
The air returns in the four 2nd floor bedrooms are near the ceiling. I know this helps in the cooling season but in the heating season should I cover the air returns on 2nd floor?
A buddy told me to cover the 2nd floor ones, take temperature reading of supply air as furnace is burning, then uncover the 2nd floor returns and take another supply air temperature reading. Compare the two and if similar, the furnace has enough return air with 2nd floor vents covered.
Any thoughts?
hammerlane is offline   Reply With Quote
Old 12-19-2011, 02:33 PM   #2
Don't do it. Your upstairs needs return air regardless of whether it's heating or cooling.
brandonmcginnis is offline   Reply With Quote
Old 12-19-2011, 03:50 PM   #3
HVAC Tech/ Browns Fan
You can close down some supply vents
Tator1076 is offline   Reply With Quote
Old 12-19-2011, 04:01 PM   #4
Dont want to close any supply vents in 2nd floor rooms. But you also suggest NOT COVERING any 2nd floor return grills near ceiling?
Old 12-19-2011, 04:04 PM   #5
That's correct.
Baseboard Heating: Can Anyone recognize this brand of baseboard heating cover? baseboard Plumbing 3 11-02-2011 11:50 PM
cover heating ducts using plastic sheeting Suns Insulation 11 10-25-2011 09:50 AM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 03:53 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
Bleeding Steam Radiator during heating season helplessowner HVAC 1 01-24-2007 01:15 PM
