Coupling New Furnace Output To Existing Flue - HVAC - DIY Chatroom Home Improvement Forum
Old 05-18-2012, 11:34 PM   #1
Coupling new furnace output to existing flue
I am replacing my old furnace with a Ruud model # RGPR-12EARMR. The old furnace has a 5" Metal-Fab B1 twist assembly flue pipe. The new furnace has a 3" outlet and specifies an immediate transition to 5" flue for the BTU of this model. The furnace also specifies that screws on the flue outlet should be predrilled. I bought a Metal-Fab 3" to 5" reducer that twists onto my existing flue very nicely. Except the 3" end isn't quite matching my furnace.
Here is the furnace outlet as delivered from Ruud:
http://img841.imageshack.us/img841/5...eoutletwit.jpg
And here is the Metal-Fab 3" end of the reducer:
http://img29.imageshack.us/img29/425...5inreducer.jpg
They do not quite fit together. The OD of the flue outlet including gasket is right at 3". The Metal-Fab inner sleeve is just under 3" and hits the gasket, so I cannot slide it onto the outlet with gasket installed.
Am I using the wrong coupler for this furnace? Should I remove the gasket? Is there a single walled coupler I should be using?
The installation manual is silent about the gasket, e.g.
https://www.rheemote.net/docstore/we...09_GPR_GLR.pdf
The AC supply store has never seen a flue outlet delivered with a gasket like this.
I would sure appreciate any advice.
Thanks a lot!
disarli is offline   Reply With Quote
Old 05-18-2012, 11:59 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
It will fit. Elbow grease while twisting. I just installed one of those Rheem furnaces with the same 3" exhaust a few weeks ago. It took a bit of work but it fit. Mine was not Metal fab though but Metal fab will fit. Leave the gasket on.
The furnace I installed was only 60k btu, didn't have to upsize the flue.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-20-2012, 09:38 AM   #3
Thanksfor the confirmation that it will fit. I have a 90 joint stuck on the reducer, so I wasn't trying to twist it on. I'll take the 90 deg off and do the twisting.
Old 05-20-2012, 10:10 AM   #4
Rewards Points: 1,214
Soap and water it will dry up don't worry about it. Lubricate it don't fight it.
COLDIRON is offline   Reply With Quote
Old 05-20-2012, 10:45 AM   #5
Sorry, I couldn' resist.
Thanks.
Old 05-20-2012, 12:55 PM   #6
":thumbsup : Back"
Tags
gas furnace flue gasket
Moving furnace & redoing ducting cbrc5eric HVAC 0 02-09-2012 09:13 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
flue pipe on 90+ furnace Landen HVAC 31 02-14-2011 09:29 AM
Furnace flue height fastfourier HVAC 10 01-18-2010 11:50 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
