Old 11-24-2012, 04:02 PM   #1
a couple of venting questions
hope you guys can help. just purchased our first house,a straight ranch slab house in mass.i have noticed some things now that the colder weather has arrived.
1. the dryer is vented into the attic and then over to the soffet.its about 4 inches from the soffet vent for the attic.now i notice when the dryer runs for a while the vent drips from the condensation outside. is this normal or is this dryer vent too close to the soffet vent for the attic?
2.we have central air,i noticed that the heat comes out of the vents close to the floor but i have a big vent on the hallway ceiling that sucks air when the heat is on.since heat rises isn't this vent sucking hot air back into the system?
3. there is a pvc stack out of the roof with an elbow at the end.i noticed now that when the heat is on condensation comes out of the end so im assuming thats the exhaust for the furnace, we have all gas.when the furnace stops for a while i notice a icicle hanging off the end, is this normal,
any info would be greatly appreciated thanks.
campingbum is offline   Reply With Quote
Old 11-24-2012, 07:58 PM   #2
An old Tradesmen
It draws the warmest air back in, which is good in a way, since it gets it off of the ceiling and circulating through the house. Normal for it to get an icicle.
Old 11-24-2012, 08:03 PM   #3
Items wanted: Time
the dryer should be piped to the outside. Condensation in the attic will surely cause mold.
supplies on the floor and return on the ceiling is fine.
condensation at the pvc elbow is normal.
NiNe O is offline   Reply With Quote
Old 12-01-2012, 05:30 PM   #4
thanks for the info,noticed that the bathroom vent is venting right into the attic so looks like another project.....
Old 12-01-2012, 08:16 PM   #5
You might want to look in the attic near where the dryer vent exits. If you see dark staining on the roof boards or other moisture indications in that area you should probably look at relocating the dryer vent or blocking off the attic vents near it.
old_squid is offline   Reply With Quote
Planning to remodel my bathrooms and have couple of questions uvasag Kitchen & Bath Remodeling 6 08-25-2011 11:30 PM
A couple of noob concrete finishing questions SMRcalidiv Building & Construction 11 07-31-2011 08:27 PM
Basement Reno Take II...A Couple of Questions monsterbash Building & Construction 3 08-25-2010 10:16 PM
Couple of (quick) questions spiragui Roofing 1 07-31-2010 05:48 AM
Couple of Code Related Questions gregt848 Building & Construction 11 12-04-2009 10:50 PM
