Old 06-10-2012, 12:32 PM   #1
Question
Could use some assistance wiring my thermostat
Here is a picture of both units.
http://i.imgur.com/mHva0.jpg
If anyone can help me,im just not sure where to connect blue on the new unit. Also, do i need the jumper between w and y on the new like that?
HarleyP is offline   Reply With Quote
Old 06-10-2012, 12:57 PM   #2
An old Tradesmen
Blue will go to the new stat's O/B terminal. No you don't need to jumper W to Y on the new stat.
Old 06-10-2012, 02:23 PM   #3
ok I did it like you suggested. Blue to O/B, and no jumper between Y and W.
But now the A/C is blowing warm air. Any ideas?
Old 06-10-2012, 02:26 PM   #4
An old Tradesmen
If your outdoor unit is a Rheem/Ruud, then se the O/B to energize for heat. if its any other brand, then O/B energizes for cooling.
Old 06-10-2012, 02:46 PM   #5
Outdoor unitis a Comfortmaker.
Here is how i have the thermostat setup
http://i.imgur.com/uFXnL.jpg
Old 06-10-2012, 02:53 PM   #6
Professional
you need to read your manual and go into the settings and set it up for heat pump without aux heat
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 06-10-2012, 03:14 PM   #7
crap sorry I always forgot about that.
Seems like everything is working now. Thanks beenthere and hvactech126 for your help!
Tags
color, jumper, thermostat, wire, wiring
heat pump wiring problem - new thermostat tygrr94 HVAC 8 01-17-2011 09:18 PM
Honeywell thermostat wiring wcb22 HVAC 5 01-10-2011 06:54 AM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Thermostat to Controller Wiring Molson HVAC 1 07-05-2010 07:24 PM
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 07:11 AM
