Cost Of Replacing Whole System - HVAC - DIY Chatroom Home Improvement Forum
Old 06-22-2009, 05:31 PM   #1
Landlord
Rewards Points: 89
Cost of replacing whole system
I can't get a cost without calling someone. I have a two story 1850 sq ft house. I have a split system that was installed in 1992. I assume I will have to get a new air handler/furnace with a new condenser unit because of the new freon. Can anyone in the know give me a ballpark figure??
cocean is offline   Reply With Quote
Old 06-22-2009, 05:43 PM   #2
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 802
What zip code?
Aggie67 is offline   Reply With Quote
Old 06-22-2009, 07:36 PM   #3
Landlord
Rewards Points: 89
Old 06-22-2009, 08:02 PM   #4
sktn77a's Avatar
Rewards Points: 360
If you go for a heatpump with coil, air handler, etc, you're probably in the region of 4000-6000. Add another 2000-3000 for an A/C with high eff furnace system. Could be less or more, depending if you go bottom of the line or top of the line.
sktn77a is offline   Reply With Quote
Old 06-22-2009, 08:39 PM   #5
Aggie67's Avatar
Rewards Points: 802
Electric or gas?
Rough guesses on sizes for Georgia climate (100,000 btu gas furnace, 5 ton ac), figuring it's a basement. Ball park is 8,600 to 12,160 installed, depending on equipment, access, and the contractor's markup practices. This is just my opinion, but somebody charging under $8k for a remove/replace is either not providing himself a living wage or staying in business, or he's selling less than good stuff. You might get it that low if someone is hungry for work, but understand that something that low carries risks.
You'll probably get a couple hundred bucks in a rebate for a high efficiency unit, and your contractor might also qualify for a rebate. Ask him about both.
Old 06-22-2009, 09:11 PM   #6
An old Tradesmen
Rewards Points: 6,060
Prices vary greatly by the region.
Since estimates are free.
Just call and have a couple contractors come out and give you some estimates.
Old 06-22-2009, 09:40 PM   #7
GC/Master Plumber/Mech
Rewards Points: 560
I'm with Been et estimates...they are free
You don't have to go with the big name HVAC companies in your town. Check out the independent companies less over head usually means lower cost and get refferences.
Old 06-23-2009, 07:45 AM   #8
Aggie67's Avatar
Rewards Points: 802
Yes, big time spread in overhead practices. Also, my numbers didn't account for the independent tradesman with basically no overhead. His numbers will generally be lower. For the consumer looking for a great combo of price and service, it might be hard to beat a really qualified local independent tradesman with an excellent reputation.
Can we get a cost estimate subforum going Will1987 Site Help and Suggestions 8 04-02-2009 08:57 AM
New System Advice jkspup22 HVAC 1 03-25-2008 09:48 AM
Cost of replacing a rafter in our roof??? bikerboy337 Roofing/Siding 3 04-24-2005 07:19 AM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 09:50 AM
