Cost For Duct Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 09:28 PM   #1
Cost for Duct replacement
New guy here. I am trying to save on some energy cost by improving the airflow from the furnace. The current design of the plenum has 12 ducts coming from the plenum out to the vents. I have had several heat and air companies out to give me quotes on a redesign of the plenum and running new duct work. The redesign will have 3 main ducts comming out of the plenum and then branches from the main duct to the vents. My quotes have ranged from $1000, $1500 to $1800. I am looking for opinions on the range of price. The 1800 dollar quote includes installing new ducts, some air balancers, new plenum, cleaning and servicing A/C and furnace. The $1000 and $1500 quote included a new plenum and new ducts. Not sure what to think about the large spread in quotes. Thanks
af2c40 is offline   Reply With Quote
Old 03-26-2012, 09:38 PM   #2
REP
The wide range has something to do with what will be done.It also has something to do with the wide differances in the amount of labor needed to do the job.
You need to see if any of them performed a manual "D".
Any other way of quoting is pure guess work.
REP is offline   Reply With Quote
Old 03-26-2012, 09:45 PM   #3
Thanks. I am learning as I go. I will ask if they used the manual D to calculate the correct design. I did not know to ask that and none of the contractors mentioned that they used it. Thanks
Old 03-26-2012, 10:09 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
Cheap is never good and good is never cheap. I can tell you right now you'd be looking at well over 3 grand if I were to do it. Heck, I wouldn't even get out of bed to simply look at that job for $1800.00.
Ask about the insulation factor of the plenum and ducts. Down here it used to be R-6 but the new city ordinance is mandating r-8 as of next year. It's the thickness of the insulation on the duct itself. R-8 is thicker. Keeps cool air cool and warm air warm and keeps it all seperated properly.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 03-26-2012, 10:15 PM   #5
Doc, you gotta remember it's still a pretty flat market in most places, And prices could be alot diff where OP lives.
hvac5646 is offline   Reply With Quote
Old 03-26-2012, 10:48 PM   #6
Thanks for the input Doc. I'm not as concerned about the price as getting it done right. I just find it interesting that the range of cost is kind of extreme. I will look into what the city code is for the insulating factor and what the contractors are planning to use. I am still researching technicians to do the job
Old 03-27-2012, 04:34 AM   #7
An old Tradesmen
Rewards Points: 6,876
A 1000 bucks for 3 trunk lines and new supply lines? Doesn't sound like they will be too concerned about how it works after its in.
Old 03-27-2012, 09:18 PM   #8
You're preaching to the choir, Young Skywalker.
Glad I live down here in the hvac capitol of the world. We don't play hack and we don't play cheap.
Thanks.
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
(true) Replacement window cost windowpoor Remodeling 20 10-05-2011 10:20 AM
cost for replacement window installation timsmeegs Off Topic 2 04-29-2010 01:14 PM
Cost of boiler & cylinder replacement abaminog Off Topic 9 03-31-2010 07:05 PM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 12:48 PM
