Old 07-24-2011, 08:47 AM   #1
Cost of 5 ton HVAC?
I don't know if we are allowed to mention specific manufacturers here so I won't until I know it is ok.
Anyway, I had an Infinity system installed in my house a couple of years ago but it was pretty expensive.
Now I am trying to buy another house that is 2.5 times larger than my current house and it has the original (1987) HVAC which isn't working.
Please suggest a high SEER 2-speed scroll compressor manufacturer that you know works well and is reliable.
Thanks!
johngalt47 is offline   Reply With Quote
Old 07-24-2011, 09:57 AM   #2
An old Tradesmen
Cost of 5 ton HVAC?
York, Carrier, Trane(the 20i line), Lennox, and any of their sister brand names. Haven't seen much of Goodman's new 2 stage line, or Amana's 2 stage line.
None of them are cheap.
Old 07-24-2011, 10:19 AM   #3
Hvac Pro
Cost of 5 ton HVAC?
Any of the names Beenthere mentioned but I am not a big fan of Lennox sister lines ( Armstrong and AireFlo/Ducane). Nothing wrong with them but you get a LOT more adjustment features on the higher end Lennox Signature series than the basic units of them and all the other brands. If you want a 2 stage system you really should get a higher end furnace/airhandler with a true ECM variable speed blower in order to get the full use/features of a 2 stage AC. Hence the more features/dip switch adjustments for fan cfm etc on the higher end units. Nothing is cheap when you are looking at those units. Basic price for an XC16 2 stage and G61V furnace here would be $10,000 and up to $14,000 with the full blown IAQ indoor air quality communicating programmable thermostats etc.
Ductless Mini Split Install - need HVAC Tech! mike_30319 HVAC 13 03-30-2011 07:18 AM
Moving HVAC system dilemma denemante HVAC 4 03-18-2011 05:55 PM
Repair or Replace HVAC System? MrBill_DIY HVAC 3 04-24-2010 09:47 PM
HVAC in out Condo Jzone99 HVAC 10 11-21-2009 05:28 AM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 08:37 PM
