Corrosion Of Condenser Fins - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 09:33 PM   #16
I'm Your Huckleberry
Rewards Points: 2,270
yeah, what size is the existing liquid line? if it's 1/4 it's too small. new liquid line drier?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-17-2013, 10:09 PM   #17
Roofmaster
Rewards Points: 2,172
If you paid for it, you should get it. Dont be intimidated. Isn't the new system 410A? I thought you could not re-use R-22 parts for R410A
Old 04-17-2013, 10:18 PM   #18
a lineset is not a part specific to any refrigerant. it can be nitrogen and rx-11 flushed to remove any and all old chemicals and oils, made like new again.
we do it all the time.
Thanks.
The Following 2 Users Say Thank You to Doc Holliday For This Useful Post:
ben's plumbing (04-18-2013), jagans (04-23-2013)
Old 04-17-2013, 10:21 PM   #19
An old Tradesmen
Rewards Points: 6,112
Heck, I just blow them out with nitrogen. Chemical flushes are mostly a waste of money and time.
The Following User Says Thank You to beenthere For This Useful Post:
Old 04-17-2013, 10:53 PM   #20
me too, I only mentioned rx-11 for the politically correct.
Thanks.
The Following User Says Thank You to Doc Holliday For This Useful Post:
Old 04-17-2013, 11:01 PM   #21
Experienced HVAC Tech
HVAC1000's Avatar
i opened up a bottle of that "Pro Flush" stuff the other day, im pretty sure its just lighter fluid or white gas or something like that. it sure smells flammable
HVAC1000 is offline   Reply With Quote
Old 04-18-2013, 07:57 PM   #22
The existing line is 5/16 inch. He left that original run in place and attached it to new 3/8 inch at the condensor and evap coils. He tested to pressure and said it was fine.
I'm conflicted- replacing it could well cause a leak. So if 5/16 is ok for that system, I say fine. I just wish he would have contacted me and told me what was up.
I have no idea how he prices his jobs. I will tell you I paid him $2700 for the job. What is fair value for around 25 feet copper line? No clue. Nor do I know what his labor would have been to replace it- maybe an hour tops?
Anyway, I'm inclined to let this one go as I imagine we're not talking much money. Serves me right for not being present when he was installing.
Damn you career!
Harpert1 is offline   Reply With Quote
Old 04-18-2013, 08:17 PM   #23
Rewards Points: 582
Damn you career!
personally I would have installed the 3/8 liquid line its 3/8 at the compressure for a reason....imo ben sr...
Old 04-19-2013, 07:17 AM   #24
Rewards Points: 1,214
I also wold have installed 3/8 if there's a 3/8 dia. connection at the condenser. I always install the size that's specified at the condenser unless it's a longer than normal run the I will think about increasing the dia.
I never install a smaller than what's at the condenser.
That means all the way from point to point.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
ben's plumbing (04-19-2013)
Old 04-23-2013, 10:19 PM   #25
Roofmaster
Thanks Doc, more BS just to sell stuff. Once again, common sense rises to the surface.
Any Issues: Old Condenser - New System? JulieMor HVAC 3 07-05-2012 08:57 PM
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 08:05 AM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 02:54 PM
Stucco Fins vs. Nail Fins on Stucco House xquercus General DIY Discussions 5 01-25-2009 05:44 PM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 07:03 PM
