Correct T-STAT For Air Conditioning/Heater Units - HVAC - DIY Chatroom Home Improvement Forum
Old 05-07-2010, 11:42 PM   #1
Correct T-STAT for Air Conditioning/Heater Units
Buyig the right T-STAT is not as easy as I thought. All i did was remove the one I had off the wall and google the part number tha is on the T-Stat PCB (TSTATCCSHP01) and ordered from PEXSupply.co. http://www.pexsupply.com/pex/control...~refine=100209
When I received it in the mail I swapped old with new and I noticed the AC was working but not blowing really cool air. Later that week my local HvAC guy came to service (yearly tune up) my unit and he told me I had the wrong T-Stat because it wasn't programming properly. I was baffled because the new TSTAT-looks exactly the same as the old one (both inside and outside). I did trust what he was saying because he ran through all the options on the T-STAT programming and it was skipping one of the options according to the T-STAT insruction manual.
Now that I lost all confidence in buying the proper T-STAT is there a way to order the correct T-STAt just by looking at the number on the product sticker that is located on the AC Unit? See attached files.
I lost the paper from my HVAC guy that said what T-STAT I needed. I think he said "heat pump" or "two stage heat pump?" but I would like to know for certain without taking anyones word for it.
Oh by the way the only reason why I replaced the old T-STAt with a new one is because the old one had paint on the plastic case.
Correct T-STAT for Air Conditioning/Heater Units-picture-1.jpg   Correct T-STAT for Air Conditioning/Heater Units-picture-2.jpg   Correct T-STAT for Air Conditioning/Heater Units-picture-3.jpg   Correct T-STAT for Air Conditioning/Heater Units-picture-4.jpg   Correct T-STAT for Air Conditioning/Heater Units-picture-5.jpg
Correct T-STAT for Air Conditioning/Heater Units-picture-6.jpg
robismyname is offline   Reply With Quote
Old 05-08-2010, 11:09 AM   #2
An old Tradesmen
Rewards Points: 7,826
Which option did it skip?
What is the model number of the outdoor unit.
Old 05-10-2010, 10:30 PM   #3
Sorry for the delay in responding. It took some time to get the answers.
The new T-Stat I bought to replace the original T-Stat only has the following options available once in configuration mode:
Option 1 -- Anticipator adjustment (2 by default)
Option 3 -- Fahrenheit or Celsius operation (F)
Option 4 -- Enable Fan (G) ON with heat (W) (On)
Option 13 -- Room Temperature offset adjustment
The original T-Stat has the following options available once in configuration mode:
Option 1 -- Anticipator adjustment (set to 2)
Option 3 -- Fahrenheit or Celsius operation (set to F)
Option 4 -- Enable Fan (G) ON with heat (W) (set to On)
Option 10 -- O(reversing valve) On with heat or cool (set to C)
Option 13 -- Room Temperature offset adjustment (set to 0)
Model Number is: 3BEYG030---301--
See attached picture
Eagerly awaiting your response...........
Correct T-STAT for Air Conditioning/Heater Units-picture-10.jpg
Old 05-11-2010, 05:01 AM   #4
An old Tradesmen
Looks like you got the non heat pump thermostat model.
Does the new one have the same terminals as the old one.
Old 05-11-2010, 07:43 AM   #5
Yes everything is identical.
Old 05-11-2010, 03:53 PM   #6
An old Tradesmen
In the install manual. Does it say for heat pump systems.
LUX digital stat Trane XE80 intermittant problem rossl56 HVAC 6 12-26-2008 05:53 AM
