Correct Boiler Settings? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-01-2011, 05:00 PM   #1
Rewards Points: 91
correct boiler settings?
I have an oil burner with a tankless coil. No separate water heater. It has two dials on the side, see attached picture.
Is the grey knob on the left a tempering valve? I can't turn it. Is there a reason for that? I assume I loosen the screw to turn it.
If that is a tempering valve, what is the grey box on the right? It looks like its set at 165.
I have steam heat.
What are the optimal settings for summer and winter?
debiasio is offline   Reply With Quote
Old 07-01-2011, 06:53 PM   #2
An old Tradesmen
Rewards Points: 8,202
The gray box, is your control to maintain the water temp in your boiler so you have hot water.
Yes, that is a tempering valve. Some need to be pulled out to turn them. Best to set it where it gives a constant hot water with minimal temp swing.
It would probably save you a lot of money to install an electric water heater, and not use teh oil boiler at all for your hot water.
Trying to wire Honeywell IAQ to Burnham RSM/96 oil boiler 6burgh HVAC 26 11-13-2010 08:21 PM
Why does my oil boiler maintain heat? secutanudu HVAC 5 10-19-2010 03:46 PM
Boiler room venting dontilgon HVAC 19 12-07-2009 05:07 PM
Main limit switch - correct settings? Vizoere HVAC 3 10-18-2009 06:20 PM
Boiler size Bonnie Youngs HVAC 29 07-10-2009 07:58 PM
