-   -   correct boiler settings? (http://www.diychatroom.com/f17/correct-boiler-settings-109394/)
debiasio 07-01-2011 05:00 PM
1 Attachment(s)
I have an oil burner with a tankless coil. No separate water heater. It has two dials on the side, see attached picture.
Is the grey knob on the left a tempering valve? I can't turn it. Is there a reason for that? I assume I loosen the screw to turn it.
If that is a tempering valve, what is the grey box on the right? It looks like its set at 165.
I have steam heat.
What are the optimal settings for summer and winter?
beenthere 07-01-2011 06:53 PM
The gray box, is your control to maintain the water temp in your boiler so you have hot water.
Yes, that is a tempering valve. Some need to be pulled out to turn them. Best to set it where it gives a constant hot water with minimal temp swing.
It would probably save you a lot of money to install an electric water heater, and not use teh oil boiler at all for your hot water.
