Old 11-01-2009, 11:50 PM   #1
nap
You talking to me?
nap's Avatar
Default corn stove questions
anybody have a corn or pellet stove?
I have been tossing around the idea but I cannot find a few things that are important like: how much does it cost to operate.
any idea how much corn a stove might burn for any given btu output.
any info is appreciated.
Old 11-02-2009, 07:08 AM   #2
An old Tradesmen
Roughly 7000 BTUs per pound.
If moisture content is 15% or less.
Check what your area charges for for corn.
Old 11-02-2009, 09:48 AM   #3
Go to hearth.com and post on the The Pellet Mill and Corn Crib. They specialize in just this sort of topic.
dac122 is offline   Reply With Quote
Old 11-02-2009, 03:33 PM   #4
nap
You talking to me?
nap's Avatar
thanks guys.
Old 11-02-2009, 09:30 PM   #5
Master Plumber/Mechanical
I have had Snow flame, American Harvest and Quadra fire stoves
Currently I have two stoves in my house and this what I use for heat. Both are Quadra fire. The first is a Classic Bay 1200 Insert and the other is a Mt Vernon.
I mix 60% corn with 40% pellets. Corn does have a higher BTU factor than corn. I have yet to see a stove that works 100% on corn. Corn doesn't ingite without the help of the pellets even at 10% moisture. Also with corn you will have clinkers in the burn pot which will need to be removed daily. Quadra fire has self ignition and work with a thermostat. Most others run constantly which consumes more fuel
This year we purchased 4 tons of pellets for a total cost of $796. Pellets are also tax exempt because they are a renewable energy.
If you use pellets make sure that they are at least 75% hard wood otherwise you are just throwing money away.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 11-02-2009, 09:58 PM   #6
nap
You talking to me?
nap's Avatar
fantastic info plumber. Thanks.
Old 11-03-2009, 06:23 AM   #7
I have a Harman Accentra. 0-40K BTU output. It heats the majority of my house. I typically burn a bag a day during the cold months. Pellets around here are about $250/ton.
jerryh3 is online now   Reply With Quote
Old 11-03-2009, 06:34 AM   #8
An old Tradesmen
Hmmm.
250 a ton. A bag a day during a cold month.
What would gas heat cost you for that same month?
Old 11-03-2009, 08:49 AM   #9
Originally Posted by beenthere View Post
Hmmm.
Don't know. Natural gas is not available at the house. I have an oil boiler as the primary heat source but bought the pellet stove when oil was pushing $4/gal. Since oil has dropped back down, the pellets aren't saving me as much, but it looks nice. And, a bag a day is probably on the very high side of what I use. Plus, with the new mini-splits, I am using those on these 30-60 degree days.
More On This Topic
With rising fuel costs and the desire to heat with renewable energy sources more people are turning to wood pellet stoves. Pellet stoves burn small wood pellets which are made from sawdust that would otherwise be put into landfills. Sawdust decomposes... Read More »
When you first start using a wood pellet stove to heat your home, it can seem tricky to light it. However, once you get the swing of it, you will find that is really is quite easy and can be accomplished with a few simple steps. Read More »
Hi my name is Uchendah Alete, and on behalf of Expert Village.com, in this clip we will be going over how to steam corn. Now we are going to steam some corn. Corn is really good for steaming, because boiling it takes a long time, and it spends all that... Read More »
Hi! This Matthew Willis with Texas Parkour. I am going to be showing you again another urban movement. This has been coined by different types of groups but mainly it is called quadra pedal motion and there is one specific vault that comes out of quadra... Read More »
Hi! I’m Sarah and I’m here at Extra Care Animal Hospital today, and on behalf of expertvillage.com I’m going to tell you a little bit about owning a lovebird. When you purchase of adopt your lovebird, if it’s on an all seed diet... Read More »
Intallation of wood stove in Garage radl2 HVAC 3 10-12-2009 10:21 PM
Gas Stove Outlet and Over the Range Microwave theatretch85 Electrical 6 04-24-2009 10:25 AM
regency free standing gas stove slr246 HVAC 0 02-26-2008 09:49 AM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 07:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 07:06 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
