Cooling A Room - HVAC - DIY Chatroom Home Improvement Forum
Old 01-29-2013, 11:43 AM   #1
cooling a room
We have no crawl space in our living room in sw fl. No place for insulation. Ceiling beams are attached to plywood attached to shingles. Ac runs constantly but doesnt cool the room. The rest of the house stays cool. Two ac units. Will an attic fan work to pull the hot air out of throom, very high ceilings(20 ft approx), without pulling the cool air out.
bigbuddy123 is offline   Reply With Quote
Old 01-29-2013, 11:47 AM   #2
Rewards Points: 12,868
Got a picture?
Trying to figure out what that ceiling looks like.
Old 01-29-2013, 04:46 PM   #3
Rewards Points: 610
Consider installing a drop ceiling and adding insulation on top of it.
NOTE: Cold air is heavier than warm air and should stay at lower level of room, however an exhaust fan could drag it out. If you were going to try it.. In this case ...SIZE definitely matters! However, I will defer to the pros out there. especially those with Southern experience.
techpappy is offline   Reply With Quote
Old 01-29-2013, 05:31 PM   #4
An old Tradesmen
Rewards Points: 6,132
In order to exhaust air. more air has to come inside. Which you would have to pay to cool.
As above, might want to consider installing a drop ceiling and insulating it.
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 03:49 PM
AC blowing cold but not cooling the room DanStone HVAC 23 03-19-2012 09:59 AM
How big should a mechanical/utility room be? reveriereptile Building & Construction 30 03-14-2012 09:11 AM
Aprilaire cooling furnace room terrytiredcold HVAC 0 06-07-2011 08:05 PM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 08:28 PM
