Cooling Relay Wires - HVAC - DIY Chatroom Home Improvement Forum
Old 05-01-2011, 02:18 PM   #1
Cooling Relay Wires
I need to find the 6 wires that hook up to the Cooling Relay in my Intertherm Electric Furnace. I found the Cooling relay but no wiring
Jostudman is offline   Reply With Quote
Old 05-01-2011, 02:44 PM   #2
JJboy's Avatar
Model# and Serial#?????????????
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 05-01-2011, 03:08 PM   #3
Feha-015ha-01......model#
feh9209-03122......serial#
Old 05-01-2011, 03:42 PM   #4
Model# FEHA-015HA-01
Serial# FEH9209-03122
Old 05-01-2011, 04:27 PM   #5
An old Tradesmen
Rewards Points: 6,870
So are you adding A/C to your furnace. That the wires aren't there.
Old 05-01-2011, 06:02 PM   #6
This unit is already equipped with A/C. The Cooling Relay cooked and fried the wires. There are 7 wires in all, coming from Fuse, Sequencers and other places. Colors are Blue Black and White wires I just need to replace them. They are different guages, some are stiff wire some are soft wire...
Old 05-01-2011, 07:15 PM   #7
An old Tradesmen
Local hardware store may have what you need. If not, an electrical supply house will. The wires and connectors to heating elements are to be high temp wire and connectors.
Old 05-01-2011, 08:09 PM   #8
Ok...
You would think that Intertherm.com would have wiring on sight... Thanks Guy's I appreciate your time. I have put out a few EMails to a couple of sights Hopefully one of them that sells the parts will have some input as well.
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
Neutral Wires Hot Problem rayray221 Electrical 7 09-20-2010 11:20 AM
Ceiling Fan installation, 3 sets of wires in ceiling southnam Electrical 3 09-13-2010 03:00 PM
Dog ate themostat wires and now the A/C Doesn't Work..HELP! exiledone1 HVAC 3 05-18-2010 05:24 PM
Heil DC90 - AC Wires keithshank HVAC 1 07-31-2008 08:37 PM
