Cooling Detached Shop - HVAC - DIY Chatroom Home Improvement Forum
Old 05-17-2010, 03:52 PM   #1
Rewards Points: 358
cooling detached shop
I have a detached shop, it is completely unfinished on the inside (just bare studs) It has NO venting what so ever, no roof vents, no gable end vents, and no eave vents. The past couple days where I live have been in the high 60s and it seemed like it was 100+ inside the shop! It is all wood construction as well with no insulation either.
I am not worried about the cold as I can handle the cold but the heat is terrible! If I throw maybe 4-6 vents on the roof will that actually do anything? Its about 250 sq ft.
I do plan on sheetrocking the walls and have been contemplating if I should insulate them but then again I want to keep the ceiling open to the raters so I can use the attic for storage. So not insulating the ceiling would defeat the propose of insulating the walls.
Any ideas?
cbzdel is offline   Reply With Quote
Old 05-17-2010, 06:02 PM   #2
An old Tradesmen
Rewards Points: 7,830
Vents won't help much. Once the roof gets hot. It will radiate heat down. So you'll still feel like its 100 when its 75 or above outside.
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 4 01-26-2011 03:21 AM
Wiring Shop Scrubbie Electrical 6 03-09-2010 06:23 PM
wiring 100A to detached garage snowman Electrical 4 11-28-2009 04:53 PM
Wiring shop need advice stqevo Electrical 14 09-03-2009 12:18 PM
Sizing wire/breaker to new shop. Roy Rowlett Electrical 8 04-22-2009 12:29 PM
