Cooling Delta T - HVAC - DIY Chatroom Home Improvement Forum
Old 04-26-2009, 02:33 PM   #1
Cooling Delta T
Outdoor Temp 91
Return Temp 70
Supply Temp 50
Delta T 20
Is a 20 difference between the return plenum and supply plenum acceptable with a 91 outdoor temperature?
mjbxx is offline   Reply With Quote
Old 04-26-2009, 04:55 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,862
That is very good! 16-18 is acceptable.
Old 04-26-2009, 05:52 PM   #3
Yea
Yea man looking good, nice spread. almost said something dirty there regarding spread.
I'll take 20 all day long.
SULTINI is offline   Reply With Quote
Old 04-26-2009, 06:23 PM   #4
Rewards Points: 129
Funny, I was going to post a similar question. On my HP, the numbers show: Return 79, supply 62, but the od was only 80. Doesn't seem to me that the numbers are all that great. What do you think?
jeepgrady is online now   Reply With Quote
Old 04-26-2009, 06:39 PM   #5
Hvac Pro
yuri's Avatar
16-18 degF is acceptable. You got 17. The numbers are NOT all of the equation and can be misleading. A dirty evap coil can cause low Delta T etc etc. You still need to get the freon level checked annually, plus amperage draw etc etc to know for sure.
Old 04-26-2009, 07:34 PM   #6
Rewards Points: 292
Turned the a/c on for the first time this season. Was 93 in Philly area (design 90).
Checked the delta; it was 23.5. Unit is set up at 360 CFM/Ton.
V
veesubotee is offline   Reply With Quote
Old 04-27-2009, 07:00 AM   #7
Me too
V
I am a hoagie and cheese steak eater to and my system is running similar to yours. I'm running 400 a ton.
Old 04-27-2009, 09:03 AM   #8
Rewards Points: 292
Who do you prefer, Pat's or Geno's? Jim's, maybe?
BTW, do you know the origin of 'hoagie'?
V
Old 04-27-2009, 12:15 PM   #9
Hoagie
V
I am not from the city I live outside just Northeast a couple miles.
Yes in regards to the HOAGIE it started at hog island, ship builders would take sandwiches to work and it started from Hog island ship builders who named it a hoagie.
No Pats, Geno's or Jim's but I would like to try one. I know where they are.
Old 04-27-2009, 01:00 PM   #10
Rewards Points: 292
I was born and raised in Philly, now live across the big river a few miles
A little history: In the 'olden' days, they were originally called 'hoggies' for hog island, but it evolved to 'hoagies'. Also, back in the late '40s, the family would take a ride to Pat's for a steak sandwich. There wasn't a piece of cheese to be found anywhere. It was added much later (mid-'50s).
Try Geno's.
V
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 4 01-26-2011 03:21 AM
Glacier Bay, Peerless, Delta Yoyizit Plumbing 2 03-11-2009 11:20 AM
concrete basement - installing laminate on delta SDG Flooring 1 12-29-2008 08:10 PM
wiring a 220 volt delta unisaw and delta x5 planer naveall Electrical 13 10-30-2008 01:30 PM
Delta table saw blade guard problem RDS Tools 7 03-07-2008 03:29 PM
