Old 06-23-2011, 01:26 AM   #1
Cooling capacity relation with air temperature.
I have noticed on some ac units the total cooling capacity at 80F air temperature is more than the cooling capacity at 75F air temp while the RH is 50% at both the temperatures. I mean why the total cooling capacity is not more at 75F?
Please help me understand how that is possible. Although the sensible cooling capacity is higher at 75F.
Samart is offline   Reply With Quote
Old 06-23-2011, 11:06 AM   #2
Are you talking window units?
HVACDave is offline   Reply With Quote
Old 06-23-2011, 08:39 PM   #3
An old Tradesmen
Less heat in the air at 75 then at 80. The A/C can only remove heat if its there to remove.
Next, 50% RH at 80 is a lot more moisture in the air then at 70.
Condensation on fiberglass window frame creamaster General Discussion 11 01-05-2012 08:42 PM
Condensation on Windows (PICS) - Advice Please livinginthepark General Discussion 16 12-20-2010 08:35 AM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
how to stop condensation on windows? cake General Discussion 7 11-22-2008 01:12 AM
Sweating windows big daddy-o General Discussion 15 01-06-2008 03:41 PM
