-   -   Cooling capacity relation with air temperature. (http://www.diychatroom.com/f17/cooling-capacity-relation-air-temperature-108538/)
Samart 06-23-2011 01:26 AM
I have noticed on some ac units the total cooling capacity at 80F air temperature is more than the cooling capacity at 75F air temp while the RH is 50% at both the temperatures. I mean why the total cooling capacity is not more at 75F?
Please help me understand how that is possible. Although the sensible cooling capacity is higher at 75F.
HVACDave 06-23-2011 11:06 AM
Are you talking window units?
beenthere 06-23-2011 08:39 PM
Less heat in the air at 75 then at 80. The A/C can only remove heat if its there to remove.
Next, 50% RH at 80 is a lot more moisture in the air then at 70.
