Cooktop As Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2014, 10:23 PM   #1
Rewards Points: 101
Cooktop as Heater
Why are you not supposed to use a cook-top as a space heater? When I was growing up my parents would light up the stove before bed on the coldest nights to keep the apartment warm.
I heard recently that it's not a good idea.
michaelson is offline   Reply With Quote
Old 01-31-2014, 10:55 PM   #2
Rewards Points: 166
Safety would be a big one. Hopefully the safety issues associated with leaving a cooktop on and unattended for long periods are obvious enough that they don't need further explanation. The other issue would be that it is a fairly inefficient way to heat your home. An inexpensive space heater would be a better option.
If you are snowed-in and freezing with no other option then it would work, just make sure to vent it if it's gas. It is still pretty common to see people heating their homes with their ovens in some places, but usually that's something you see in situations where they aren't paying for the utilities.
dftc is offline   Reply With Quote
Old 01-31-2014, 11:46 PM   #3
Rewards Points: 101
How efficient would the cheap space heater be compared to the cooktop? I was thinking that the space heater being electric would end up costing more than the cooktop because it's gas.
Technically you're not supposed to go to sleep with the space heater running either.
Old 02-01-2014, 03:48 AM   #4
Rewards Points: 166
It may be more efficient than electric, I don't know where you live and what the prices are.
The big dangers here are CO poisoning and fire. Both situations can and do happen to hundreds of people every year in the US from doing exactly what you are talking about. Usually I see people boiling large pots of water.
An open flame inside your home will use up oxygen and produce CO. If you don't have a fresh air source coming in then it will build up over time and you may have no idea until it's too late. Two or three hours is not a big deal. Overnight definitely could be. This is why a furnace uses a heat exchanger.
I am not being as alarmist about this as I really want to be because I know a lot of people do use this heating method and if you are really cold you might feel like you have no other option.
If you are going to do this then get a CO detector and read up on the signs of CO poisoning. Better yet get an inexpensive electric oil space heater from Walmart and put a couple extra blankets on the bed.
Old 02-01-2014, 05:27 AM   #5
An old Tradesmen
Rewards Points: 8,234
A range top puts off high CO, and can cause death.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
2 yr old gas water heater not lighting up, signal light on amakarevic Plumbing 14 12-17-2013 07:37 PM
Need input on indirect fired water heater install. A Squared HVAC 13 11-23-2013 04:42 PM
Water Heater Height Factor in Install Cost? hefret Plumbing 9 10-10-2013 10:01 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
