Converting Wood Fireplace To Propane - HVAC - DIY Chatroom Home Improvement Forum
Old 12-17-2009, 10:39 PM   #1
converting wood fireplace to propane
Have a large stone fireplace with custom glass doors that are very air tight. Have an ash dump that goes to the outside. Trying to decide if I can use gas logs, close and seal the glass doors so as not to loose inside air, get my air from the ash dump and vent up the chimney. This would be much less expensive than a self contained gas insert. What problems would I encounter?
tonyraydeal is offline   Reply With Quote
Old 12-20-2009, 12:21 AM   #2
Your ash dump probably won't provide enough oxygen for combustion. Have you given any thought to a set of vent-free gas logs for your fireplace? They will allow you to close your damper and open the doors so you can get all the heat into your house.
log_doc_rob is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 09:17 AM
