Converting Steam To Hot Water - HVAC - DIY Chatroom Home Improvement Forum
Old 01-15-2009, 01:00 PM   #1
Converting Steam to hot water
Our condo has 1-pipe steam which we want to convert to 2-pipe water using "single entry injection valve" (see www.hydronicalternatives.com ) technology.
We plan on using pex and bypassing the old system entirely.
Has anyone done this? Are there contractors who specialize in this?
theaccountant is offline   Reply With Quote
Old 01-15-2009, 01:14 PM   #2
JohnH1's Avatar
Sure but it is expensive to do. 1st thing to do is a full heat load to see if the existing radiators will produce enough heat for the building at the lower water temps. Steam ran at 212+ water normally around 140 to 160 for radiators.
JohnH1 is offline   Reply With Quote
Old 01-15-2009, 02:50 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,602
theaccountant
Ayuh,... The Accountant for Hydronic Alternatives I presume,..??
Nice Radiators,....
Lame Attempt at Spamming though.....
Bondo is online now   Reply With Quote
Tags
convert , pex injection , steam
Converting steam heat to hot water??? pcampbell HVAC 31 02-17-2009 08:26 PM
Converting Steam Radiators To Hot Water johnpar HVAC 4 07-30-2008 03:34 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
