Converting Propane Boiler To Natural Gas - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2009, 09:43 PM   #1
Rewards Points: 150
converting propane boiler to natural gas
what is involved in converting a boiler that runs on propane to natural gas? i want to buy this used one to put in my house and run it off of natural gas. the guy said it used to run on natural gas but was converted to propane, so i assume i could convert it back.
drewhart is offline   Reply With Quote
Old 01-14-2009, 12:21 AM   #2
Rewards Points: 150
is it just a matter of putting a different valve on?
Old 01-14-2009, 12:35 AM   #3
How do you know the boiler is the right size for your home and if it's in working order?
Is it steam or hot water?
hvaclover is offline   Reply With Quote
Old 01-14-2009, 09:05 AM   #4
Rewards Points: 150
it is hot water. i dont know if its the right size. the house is 1900 sq.ft and the boiler is a weil mclain 140,000 btu. will this suffice? i just need some heat! this one i can get a good deal on, i just dont want to spend 3,000 on a new one.
Old 01-14-2009, 10:23 AM   #5
seems way over sized to me.
Old 01-14-2009, 01:35 PM   #6
Rewards Points: 150
is it ok to use one way oversized?
seems to me i could run it low which would preserve it's usefull life.
this seems better that running one high which is too small right?
so what is involved in switching to natural gas?
Old 01-14-2009, 02:06 PM   #7
An old Tradesmen
Rewards Points: 6,060
Proper sized orfices, gas valve and or spring, new burners on some models.
Also need a Manometer.
Takes the same water temp weather the boiler is over or undersized.
If the the boiler holds more water then the current one, the you also increase its standby lost, increasing how much more gas you will use.
Also, if its larger then the old boiler(BTU wise) it will need more combustion air, meaning it draws more fresh air into the house. Which you have to pay to reheat.
Your chimney may not be able to handle the larger boiler.
Attempting to derate a boilers input, can cause condensate troubles in both the boiler and chimney.
Improper conversions have caused more then one fire.
And way too many CO posionings.
Old 01-14-2009, 05:21 PM   #8
Been correct me if I am wrong: Derating in excess of 20% will definitely cause condensation. For a 1900 sqft home you don't even need 100k, no?
So wouldn't derating this boiler be a very chancy since the amount of reduction far exceeds 20%?
Old 01-14-2009, 06:07 PM   #9
An old Tradesmen
Some units have problems if you try even 10%.
Might only need 80,000 for it.
Old 01-14-2009, 08:09 PM   #10
Rewards Points: 150
I am not an HVAC tech nor do I play one on TV! But wouldn't the type of house,insulation ,windows and geographic area come into play?
Gary
Gary_602z is offline   Reply With Quote
Old 01-14-2009, 08:20 PM   #11
Rewards Points: 150
its a stucco house in cleveland ohio. the upstairs 4 bedrooms have been framed-in with insulation. downstairs is the original stucco/plaster walls with no insulation. all new windows up, all old windows down. i just read today on the boiler that it is 131,250 btu. it doesnt indicate whether thats input or output. there is a rating called "water sq. ft" of which it says 700. the one i want to put in here has a btu rating of 140,000.
Old 01-14-2009, 08:26 PM   #12
JohnH1's Avatar
Think about why you are getting this boiler for such a deal. Someone els removed it for some reason. That is a lot of work to install a used boiler and then have problems. If not a leak.
JohnH1 is offline   Reply With Quote
Old 01-14-2009, 08:33 PM   #13
Rewards Points: 150
of the two i am trying to decide betweem, one was replaced because they invested in a new high efficiency boiler, the other because they switched over to furnace heat. before i buy it, i want to attach a fitting so i can compress air into it to see if it leaks. is this a viable test?
Old 01-14-2009, 08:40 PM   #14
An old Tradesmen
Gary
Which is why I said "might" only need 80,000.
Old 01-14-2009, 08:42 PM   #15
Hvac Pro
yuri's Avatar
Rewards Points: 1,088
NO! Boilers have to be heated up and full of water to see if they leak. It may lose air pressure but hold water when the sections expand. Boilers are tested with hydrostatic (water pressure).In my area there is no such thing as DIY major furnace repairs/conversions as you have to take out a permit/be licensed etc for safety and liability and insurance co. reasons. Beware if something goes wrong the fire inspector and insurance company will hang you by your neck/lawsuits etc etc.
Propane tank was empty boiler does not start schrubber HVAC 3 12-30-2008 05:36 PM
converting to propane bigdog HVAC 11 12-23-2008 02:20 PM
Propane to Natural conversion higgsfamily5 Appliances 5 11-06-2008 10:51 PM
