Old 09-02-2008, 12:18 PM   #1
converting to propane
I like to replace my old oil based heating system to a propane based system. Is it possible to convert the old oil tank to a propane tank?
Thanks.
bigdog is offline   Reply With Quote
Old 09-02-2008, 05:58 PM   #2
1610 CUB's Avatar
No! It Cant!
1610 CUB is offline   Reply With Quote
Old 09-02-2008, 06:00 PM   #3
oops, did I do that!
Your old oil tank can be converted to a really nice barbecue, but no...not to a propane tank.
Whomever you select to service your propane will sell or lease you a tank.
8 Ball is offline   Reply With Quote
Old 09-02-2008, 06:41 PM   #4
the Musigician
DangerMouse's Avatar
a buddy of mine cut his in half and made a "hillbilly hot tub".... seriously.
DM
Old 09-02-2008, 06:58 PM   #5
Now that...I would like to see...preferably with him not in it.
Old 09-02-2008, 07:08 PM   #6
the Musigician
it was wiggly along the long edge, so i told him to run a 2x4 on the saw and make a long groove and then glue it to the edge. heh heh it worked fine. he then put a section of privacy fence to an unused side door and made a naked walkway. real deal. it's too funny, but he loves it on a hot day. i've not used it, nor want to. lol
DM
Old 09-04-2008, 06:28 PM   #7
HVAC Sales
No, Contact your propane company first.
Silent Bob is offline   Reply With Quote
Old 09-05-2008, 01:53 PM   #8
Nope. No way can you use an oil tank for propane storage. Don't take this personal, but since you're asking this type of question, I suggest you get a pro to do this for you.
dac122 is offline   Reply With Quote
Old 09-05-2008, 03:16 PM   #9
Whatamess
You better do the math before you switch. I made that mistake. Gas heats faster but there are more btus of heat in a gallon of oil than gas. I found this out to late.
I would never make that mistake again.
The bad part is it is all expensive.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 09-08-2008, 08:43 AM   #10
Yes, you need to take into account 3 things for that comparison: price of the fuel, BTU content of the fuel and efficiency of your furnace/boiler. You are after the lowest BTU cost.
This is a generalization, but in most places natural gas is cheapest. A long way off from that is propane, then oil and electric are neck and neck. Wood, coal, pellets trump all these, and a heat pump can have lower costs in mild weather. Again a generalization, at this moment, but do make sure you do the math.
Old 12-23-2008, 01:49 PM   #11
Can you give the comparison of the prices of these types of fuel?
Last edited by AtlanticWBConst.; 12-28-2008 at 06:54 AM. Reason: SITE RULES VIOLATION: Advertising Link Removed from Signature
johnpierce79 is offline   Reply With Quote
Old 12-23-2008, 02:20 PM   #12
To compare the cost of 1 million btu's of heat for an NG furnace compared to a heat pump:
Gas furnace with gas at $1.90 per therm, 95% efficient furnace:
(1,000,000 / 103,000 btu per therm) x 1.90 / .95
= $19.41
16 SEER 3 Ton Goodman Heat pump with electricity at 15.7 cents per KWH , C.O.P. = 3.5 at 35F:
(1,000,000 / 3414 btu per KHW) x .157 / 3.5
= $13.13
propane heat sharpeidar HVAC 1 12-04-2007 08:17 PM
Propane heating questions Badfish740 General Discussion 1 09-25-2007 08:46 PM
Propane hot water heater philmeister Plumbing 3 04-29-2007 08:20 PM
Propane Smell sjhandy1971 HVAC 4 01-06-2007 05:54 PM
