-   -   converting to propane (http://www.diychatroom.com/f17/converting-propane-26150/)
bigdog 09-02-2008 11:18 AM
I like to replace my old oil based heating system to a propane based system. Is it possible to convert the old oil tank to a propane tank?
Thanks.
1610 CUB 09-02-2008 04:58 PM
No! It Cant!
8 Ball 09-02-2008 05:00 PM
Your old oil tank can be converted to a really nice barbecue, but no...not to a propane tank.
Whomever you select to service your propane will sell or lease you a tank.
DangerMouse 09-02-2008 05:41 PM
a buddy of mine cut his in half and made a "hillbilly hot tub".... seriously.
DM
8 Ball 09-02-2008 05:58 PM
Now that...I would like to see...preferably with him not in it.
DangerMouse 09-02-2008 06:08 PM
it was wiggly along the long edge, so i told him to run a 2x4 on the saw and make a long groove and then glue it to the edge. heh heh it worked fine. he then put a section of privacy fence to an unused side door and made a naked walkway. real deal. it's too funny, but he loves it on a hot day. i've not used it, nor want to. lol
DM
Silent Bob 09-04-2008 05:28 PM
No, Contact your propane company first.
dac122 09-05-2008 12:53 PM
Nope. No way can you use an oil tank for propane storage. Don't take this personal, but since you're asking this type of question, I suggest you get a pro to do this for you.
TazinCR 09-05-2008 02:16 PM
You better do the math before you switch. I made that mistake. Gas heats faster but there are more btus of heat in a gallon of oil than gas. I found this out to late.
I would never make that mistake again.
The bad part is it is all expensive.
dac122 09-08-2008 07:43 AM
Yes, you need to take into account 3 things for that comparison: price of the fuel, BTU content of the fuel and efficiency of your furnace/boiler. You are after the lowest BTU cost.
This is a generalization, but in most places natural gas is cheapest. A long way off from that is propane, then oil and electric are neck and neck. Wood, coal, pellets trump all these, and a heat pump can have lower costs in mild weather. Again a generalization, at this moment, but do make sure you do the math.
johnpierce79 12-23-2008 12:49 PM
Can you give the comparison of the prices of these types of fuel?
dac122 12-23-2008 01:20 PM
To compare the cost of 1 million btu's of heat for an NG furnace compared to a heat pump:
Gas furnace with gas at $1.90 per therm, 95% efficient furnace:
(1,000,000 / 103,000 btu per therm) x 1.90 / .95
= $19.41
16 SEER 3 Ton Goodman Heat pump with electricity at 15.7 cents per KWH , C.O.P. = 3.5 at 35F:
(1,000,000 / 3414 btu per KHW) x .157 / 3.5
= $13.13
