Converting From Oil To Natural Gas - HVAC - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 07:13 AM   #1
Rewards Points: 160
Converting From Oil to Natural Gas
I'm trying to figure out if converting to natural gas will be worth the money spent.
House is 1 story, 1500 square feet, 2 zones, hot water baseboards, programmable thermostats. I just had an energy audit done, there's no major issues, but the insulation is inadequate. That will be fixed immediately. I keep the house at 60 for most of the day while working and sleeping and 64 for about 5 hours the rest of the day.
Right now I have a 7 year old Weil McLain boiler, tested at 85% efficiency. The oil tank is inside the house. DHW to the house is provided by electricity. Oil right now is $3.69/gallon and I'm using way too much. My local utility company will install a gas line from the curb to the house for free. Their rates for natural gas are $.44 a therm for the first 50 therms and $.12 after that.
Can anyone shed some light on the conversion, etc, along with tax incentives?
matt151617 is offline   Reply With Quote
Old 01-07-2012, 07:29 AM   #2
hvac
yes, I would any day of the week,It is much cheaper, it ppay off in no time, all your investment on your new unit and pipeline.
chshininc is offline   Reply With Quote
Old 01-07-2012, 07:57 AM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by matt151617 View Post
...converting to natural gas will be worth the money spent.
In nearly every instance it will be.
The exceptions are 1) if NG isn't readily available and
2) the oil burning appliance is new or close to that.
You fall into that second category.
In about 5-8 years...
In the meantime focus on insulation.
hth
Old 01-07-2012, 08:17 AM   #4
hvac
I would have gas company to go ahead and get it install( since its free), ready for you when you can afford to pay for your unit.
Old 01-08-2012, 09:17 AM   #5
Rewards Points: 160
Gas company won't install a line until I commit to some kind of usage. It has to be cost effective to them.
How long should I wait until converting to gas then? Basically, at what age/efficiency is my oil boiler no longer cost-effective?
Old 01-08-2012, 10:00 AM   #6
MarginallyQualified
What am I... chopped liver?
In about another 5-8 years... the installed equipment cost will be mostly utilized enough that the pendulum swings toward justifying the expense of change.
Not 100%... a good boiler will/can remain a good boiler for 30 years or more.
Continued operating efficiency is about maintenance of the burner...
and the distribution controls being used.
Well, unless you're loaded and can afford the upfront costs for the change.
(oil tank & lines demo, boiler demo, proper & approved disposal, maybe some asbestos pipe insulation issues, the gas pipe work, very likely flue changes, the new boiler, the new controls, etc).
hth
Old 01-08-2012, 12:22 PM   #7
Rewards Points: 160
Sorry, I thought you meant the 5-8 years was the time it would take to break even on the cost of a new gas boiler.
Old 01-08-2012, 12:27 PM   #8
Rewards Points: 1,192
Supposedly,the Shale gas bonanza will drive ng prices down.
bobelectric is offline   Reply With Quote
Old 01-09-2012, 04:34 PM   #9
Rewards Points: 160
I also heard someone talking about a mini-split heat pump system. I know they produce heat with electricity, which isn't great, but how about using the mini-split to heat in all but the coldest months, and the oil boiler would take over then?
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Help needed converting a gas valve from natural gas to propane ranis5 HVAC 0 10-24-2011 10:42 PM
Refinishing Natural Oak Cabinets without stain Ceo Painting 2 07-10-2011 10:52 AM
converting LP furnace to natural gas country boy HVAC 3 01-11-2010 07:12 PM
converting propane boiler to natural gas drewhart HVAC 25 01-15-2009 05:23 AM
