Converting LP Furnace To Natural Gas - HVAC - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 04:45 PM   #1
converting LP furnace to natural gas
I am getting natural gas brought down my street now. I have been told all i have to do to convert my lp furnace to natural gas is change out the orphases (hope you understand what i tried to spell lol). Is this true? If so how much does a new set of orphases cost?
country boy is offline   Reply With Quote
Old 01-11-2010, 04:56 PM   #2
It all depends on your furnace. You will at least need the natural gas orifices and more than likely a gas valve regulator spring. Before putting the unit into service you will need to have the manifold pressure set as LP is set at a higher pressure.
SKIP4661 is offline   Reply With Quote
Old 01-11-2010, 06:33 PM   #3
Thanks for taking the time to responde I appreciate the help. Will the spring come with the orifices or will that be a seperate purchase?
Old 01-11-2010, 07:12 PM   #4
Get ahold of the company in your area that carries your brand of furnace. They will be able to order the right parts for you . They are cheap.
Natural Gas Furnace Limit Switch 04gt HVAC 5 12-12-2009 07:50 AM
Installing natural gas furnace in place of heat pump, please help KlamathMog HVAC 17 10-20-2009 01:55 PM
converting propane boiler to natural gas drewhart HVAC 25 01-15-2009 05:23 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
