Converting HVAC 10 Inch Duct To 6 Inch HVAC Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 06-05-2011, 01:10 PM   #1
Converting HVAC 10 inch duct to 6 inch HVAC duct
Can you convert a 10 inch duct to a 6 inch feed vent?
Poochie64 is offline   Reply With Quote
Old 06-05-2011, 01:12 PM   #2
An old Tradesmen
Rewards Points: 6,480
If your talking a round duct. Not a good idea, as it will restrict air flow too much, and harm the equipment.
Old 06-05-2011, 01:21 PM   #3
So, if I have 6 inch feed vents, and had 6 inch ducts that were change to 10 inch to get more air flow, can I keep the 6 inch feed vent. If so, how?
Old 06-05-2011, 01:25 PM   #4
So if I already have 6 inch feeders, but replace a 6 inch duct with a 10 inch duct, can I use a 6 inch converter, or do I need to change the feeders to 10 inches?
Old 06-05-2011, 01:28 PM   #5
An old Tradesmen
You only gain slightly keeping the 6" take offs/start collars. Best to use the same size start collars/take offs as the pipe will be.
Be careful going to 10" pipe. It will have a much lower velocity, unless you have a lot more air going through it then the current 6" does(as in 3 to 4 times as much air).
Old 06-05-2011, 02:18 PM   #6
Hvac
Can you change a 2 ton HVAC to a 2 1/2 ton HVAC without switching out the unit?
Old 06-05-2011, 03:20 PM   #7
An old Tradesmen
No. It would be nice if you could though.
Openings in air intake duct on central HVAC system Omegazz HVAC 5 04-01-2010 01:59 PM
HVAC duct work is driving my family insane! Taipans HVAC 6 02-05-2009 12:01 PM
Properly Sealing HVAC Duct Work craymer45 HVAC 5 11-06-2008 09:47 PM
Random HVAC duct in garage...help! gone_fishing HVAC 4 07-26-2008 03:04 PM
Heater Return duct - Moved to HVAC forum backpacker2 HVAC 1 05-16-2007 12:30 PM
