-   -   Converting HVAC 10 inch duct to 6 inch HVAC duct (http://www.diychatroom.com/f17/converting-hvac-10-inch-duct-6-inch-hvac-duct-106693/)
Poochie64 06-05-2011 12:10 PM
Can you convert a 10 inch duct to a 6 inch feed vent?
beenthere 06-05-2011 12:12 PM
If your talking a round duct. Not a good idea, as it will restrict air flow too much, and harm the equipment.
Poochie64 06-05-2011 12:21 PM
So, if I have 6 inch feed vents, and had 6 inch ducts that were change to 10 inch to get more air flow, can I keep the 6 inch feed vent. If so, how?
Poochie64 06-05-2011 12:25 PM
So if I already have 6 inch feeders, but replace a 6 inch duct with a 10 inch duct, can I use a 6 inch converter, or do I need to change the feeders to 10 inches?
beenthere 06-05-2011 12:28 PM
You only gain slightly keeping the 6" take offs/start collars. Best to use the same size start collars/take offs as the pipe will be.
Be careful going to 10" pipe. It will have a much lower velocity, unless you have a lot more air going through it then the current 6" does(as in 3 to 4 times as much air).
Poochie64 06-05-2011 01:18 PM
Hvac
Can you change a 2 ton HVAC to a 2 1/2 ton HVAC without switching out the unit?
beenthere 06-05-2011 02:20 PM
No. It would be nice if you could though.
