Converting From Ge 97f9898 To Turbo 200 - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-27-2012, 01:46 PM   #31
Update - smoke pouring out of the compressor
Took the Turbo 200 back as suggested. Purchased the digital meter to be able to test mfd. The GE compressor/fan capacitor is fine. The separate start capacitor was not okay. Checked for power at the emergency disconnect and there was none. Double checked all fuses in fuse box and shut everything off and restarted. Power back at the emergency disconnect. Got all hooked back up and this is what happened. The thermostat inside the house was in the off position - so the A/C was off. When I put the emergency disconnect back in, the fan immediately started spinning. (Was that supposed to happen? I thought maybe there was a charge in the capacitor??) My wife turned on the unit inside and smoke start pouring out of the compressor. We shut everything off. I assume I need a new compressor now. Can I do this myself?
Side note: Prior to the A/C not blowing cold air anymore; my wife and daughter said that 3 times that day the power in the house flickered though we weren't having bad weather and I noticed a Centerpoint Energy truck in the area. Could these power surges be connected to what happened or did what was going on with the A/C cause the surges?
All suggestions and help appreciated.
Handyman67 is offline   Reply With Quote
Old 04-27-2012, 02:04 PM   #32
AKA HVACTECHFW
Rewards Points: 1,208
You need to remove the compressor power cover and check the connections at the terminals. There is a high probability that the wires are fried from a poor connection.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-27-2012, 02:22 PM   #33
Removed cover to find the charred remains. The cover was melted on the inside. There was definitely a fire in there. Here are some pics:
Old 04-27-2012, 02:23 PM   #34
Old 04-27-2012, 02:57 PM   #35
Rewards Points: 150
That does not look good at all! I hope your compressor is ok, if not you might as well get a new condenser. The cost of a new compressor is almost the same or maybe few more bucks plus labor. See if u can test the compressor terminals. Pull the wires off the compressor terminals. Check for continuity between each terminal. They all should have continuity between each other. (pin to pin). If they dont you got a problem. LOL
Here's a link about testing Ohms for compressors.
http://www.snipsmag.com/Articles/Fea...00f932a8c0____
Check that out also. Or it might be a good idea now to throw in the towel and call in a pro.
Good luckk
kilosos2 is offline   Reply With Quote
Old 04-27-2012, 03:25 PM   #36
An old Tradesmen
Rewards Points: 6,886
Yes, the flickering power could have cused the problem. man y electric companies will pay for the repair if they caused the problem.
Old 04-27-2012, 04:26 PM   #37
Good luckk
All the leads are melted together so I can't check the continuity.
2 full days of trying to fix this - The towel has been thrown in. I have a pro coming tomorrow.
I called the power company that we saw out here working on the lines to try and file a claim. We'll see if they get back with me. Any tips about how to deal with them would be appreciated.
Thanks to everyone for all of your help.
Old 04-27-2012, 04:32 PM   #38
An old Tradesmen
You'll need the report from the HVAC company of what is wrong. And probable cause.
Old 04-28-2012, 09:48 AM   #39
I'm Your Huckleberry
Rewards Points: 2,270
Originally Posted by Handyman67 View Post
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-29-2012, 12:43 PM   #40
looks like the fusite may have blown.
hvac5646 is offline   Reply With Quote
Old 05-02-2012, 03:37 PM   #41
I want to run some #'s past you guys and I have one question. The air handler and coil in the attic were replaced about 4 yrs ago. We are all electric.
This is a quote I received and it seems really high. To replace the condenser with a Trane XR13 and replace the air handler and evaporator coils and a new thermostat - $8085 or the Trane XR15 condenser/air handler/evaporator coils/thermostat $8,390. I won't even bother with the more expensive ones..I really can't afford these two. He also quoted an xb13 cond/air handler/evaporator for $6915.
Is Amana a good brand? A guy is preparing a quote for an Amana system and is going to send it to me later today.
Is it a bad idea to just replace the condenser with another R-22 unit, so that I don't have to change anything in the attic.
Thanks for your help.
Old 05-02-2012, 03:52 PM   #42
Amana is a glorified Goodman, the higher end equipment. Same company though, same coils. The higher seer rating equipment is Amana, the lower would be Goodman.
I don't know what your seer rating is for your currently fried system but if it's a old 9 or 10 seer than you'll notice a big difference in your electric bill even if you go to the minimum made 13 seer.
Not bad prices, about fair I'd say. Slightly high to myself but nto out of the ordinary.
The condenser and the coil need to match in seer rating or you will lose efficiency.
Might think about the condenser and the evaporator only to save money. I believe that your furnace will still be blowing the same amount of air as a new one would.
I thought the city was going to pay for this?
Thanks.
Old 05-02-2012, 04:01 PM   #43
We have filed a claim, but I don't know if I will ever hear anything back. I have been told by the guys doing the quotes not to hold my breath. They have never seen the electric company pay.
Our burned up condenser is a 12 seer and the coil is a 12 or 13 seer. I heard one of the guys say. Would I have to open the air handler to know for sure what the seer is on the coil? Will there be a manufacturers sticker?
Old 05-02-2012, 04:06 PM   #44
We work for tips.
Yes, open up the air handler and there'll be a sticker on the inside with the manufacture, model and serial number. Retrieve that information and post it. If you hurry I can call the manufacturer, if it's a brand I know, directly and find out.
Also get the make, model and serial number of the condenser.
Thanks.
Old 05-02-2012, 04:22 PM   #45
An old Tradesmen
Considering that R22 has recently doubled in price, and in another 3 years another annual production cut back is coming, which could double its price again. Staying with R22 is not really a great idea.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (05-02-2012)
Tags
capacitor , changing capacitor , contactor , hvac , turbo 200
Converting 24" on center to 16" on center newbie731 Carpentry 19 02-24-2011 02:22 AM
converting laundry room to bathroom brandisophie Plumbing 8 11-07-2010 01:10 PM
Converting outdoor gas lamp to solar? PRedLSU Electrical 7 04-30-2010 08:49 PM
Converting carport to Garage 53buick Building & Construction 2 03-15-2009 04:17 PM
Converting Steam Radiators To Hot Water johnpar HVAC 4 07-30-2008 03:34 PM
