Converting 3 Zones To One Where Do I Put Thermostat? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 06:59 PM   #1
Converting 3 zones to one Where do I put thermostat?
I want to convert a 3 zone hot water system to one zone. Where should I put the thermostat on the first, second or third floor?
h82diet is offline   Reply With Quote
Old 10-27-2011, 07:07 PM   #2
biggles's Avatar
the wall nearest the stair case if the living room has the most glass and hi ceilings the stat will monitor that area and the 2nd and 3rd will follow..if your over heating those top floor adjusting the louvers might temper it down
Old 10-27-2011, 07:11 PM   #3
the stairs are closed off....the heat doesn't cirulate up
It's an old house and the stairs are out in a hall way that is closed off by doors so the air doesn't circulate between the floors. It's all hot water baseboard.
Old 10-27-2011, 07:30 PM   #4
biggles's Avatar
any interior wall in the living room close to the hallway
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Need help replacing an OLD General Controls Thermostat ohman HVAC 3 06-08-2011 05:35 PM
Two heating zones in house -- thermostat question 19mquinn79 Electrical 2 05-03-2011 06:57 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 11:46 AM
