Converted Furnace Harmonics - HVAC - DIY Chatroom Home Improvement Forum
Old 04-02-2010, 05:04 PM   #1
converted furnace harmonics
My Sears furnace, converted from NG to LPG, during warmup, produces harmonics similar to a trombone, and the noise subsides after ~30 seconds.
What causes this musical phenomenon?
Thanks.
leehinkleman is offline   Reply With Quote
Old 04-02-2010, 06:10 PM   #2
An old Tradesmen
Rewards Points: 6,590
Could be low gas pressure to the furnace.
Or the gas valve itself.
Old 04-02-2010, 06:22 PM   #3
Exclamation
Interestingly. It's similar to a window a/c unit. If there's too much of a voltage drop (undervoltage) for any reason, it will rattle the frame until it reaches full operating capacity (in terms of running RPM.)!
spark plug is offline   Reply With Quote
Old 04-02-2010, 06:49 PM   #4
An old Tradesmen
Something like that.
Take a soda bottle. Blow across it. And it makes noise. If the pressure is too low going through the valve, it can sign a little.
Old 04-03-2010, 12:34 AM   #5
Thanks, and I think(and hope) that's exactly what's happening: low pressure from the supply to the valve, and even lower pressure from the valve to the furnace, which I think will become quieter when I get the correct supply, to the correct valve.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
