Convert Single To Dual Zone? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-15-2010, 01:23 PM   #1
convert single to dual zone?
What is involved in converting a single zone HVAC to a dual zone system using one compressor? Given all my existing parts will remain and no new condenser or evaporators will be added, I assume it will require a baffle/damper to direct the air to up/down/both areas depending on which thermostat get triggered. What parts best suit this type conversion? Is there an intermediate circuit board which would be required?
HVAC:
Vendor: Lennox
CONDENSER: 10AC42-3P
EVAPORATOR/HEAT: 80MGF3/4-100A-1
Approx: ~15 yrs
HOUSE:
- Built in 1995
- 2200sf with existing thermostat on lower level.
- Evaporator and heater (gas) are in the attic.
- All vent lines are very accessible in the attic.
Regards,
-Inet
inetquestion is offline   Reply With Quote
Old 06-15-2010, 03:50 PM   #2
An old Tradesmen
Rewards Points: 7,370
Zone panel.
Motorized Dampers.
Bypass damper.
Thermostat/stats.
Old 06-15-2010, 06:18 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,274
That furnace is prone to cycling on the limit control (lower temp type) so I would not want to throttle the airflow with dampers etc or it may be a problem. A newer furnace Lennox G71 with a variable speed ECM motor or G60UHV will handle that situation better. I have worked on hundreds of 80MGF/G24s.
Tags
convert , dual , lennox , single , zone
Convert single pole switch to a 3 way! Wildie Electrical 19 05-13-2010 10:20 AM
Single or Dual Return Duct Earnie HVAC 8 01-02-2010 05:19 PM
Adding new zone makapacs HVAC 0 11-26-2009 12:35 PM
help with third heat zone i just put in... wombosi HVAC 6 04-21-2009 12:02 PM
single stage and dual stage heat pump vshaynes HVAC 1 10-07-2008 09:18 PM
