Convert R22 Evap Coil To R410a - Need TXV - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-09-2011, 06:19 PM   #16
Just wait untill you have to clean it out of a system. You will have a much different opinion.
Master of Cold is offline   Reply With Quote
Old 09-09-2011, 08:13 PM   #17
I learned that the hard way.
Old 09-10-2011, 04:55 AM   #18
An old Tradesmen
Rewards Points: 7,414
Originally Posted by AirstarFilters View Post
Yet to experience. Lots if nay saying contractors , zero home or business owners. Used in automotive industry with smaller orifices for tears.
Yep. And lots of those systems have been back to the shop to have their screens and orifices changed out.
The garage just down from me, makes lots of money on systems that have had leak stops put in them.
Old 05-21-2015, 08:25 AM   #19
Rewards Points: 18
Hi Raylo,
I was wondering if you ever were able to install the Carrier coils in your R22 A/C HVAC system? If so, can you please tell me how it went? Was it do able?
Also, I live in NJ and none of the local distributors are willing to sell me the coils. I called about 6 places. They all want to install it. Did you run into that issue?
Has anybody else faced this issue, where they are not willing to sell you parts? Its such a pain...
Thanks,
John M.
ashishm02 is offline   Reply With Quote
Old 05-21-2015, 08:37 AM   #20
Rewards Points: 77
What's your full unit model number , if the coil's available...we can get it. Funny how now we're learning about the real reason for clogged TXVs and screens - R410a breaking down the gasket / seals in the valves...NOTHING to do with Super Seal , A/C Leak Freeze and similar products.
Filtration / HVAC & Indoor Air Quality Solutions
AirstarFilters is offline   Reply With Quote
Old 05-21-2015, 08:45 AM   #21
Rewards Points: 18
Thanks Airstar. I used a electronic leak detector and it seems like the evap coils are leaking. I am putting the UV dye in tomorrow to confirm, but 90% that the coils are leaking. The coil model number is: CNRVP3617ACA
Btw, is this normal practice for Carrier dealers? To not sell parts to consumers? Also, thats good to know about the R410A. Scary, but good to know...
Old 05-21-2015, 09:36 AM   #22
Rewards Points: 3,256
First I have heard of this. Can you share where you got the information from?
zappa is offline   Reply With Quote
Old 05-21-2015, 10:03 AM   #23
Rewards Points: 3,848
It's not the refrigerant, it's an additive that was being added to the compressor oil from Copeland causing failed TXVs.
roughneck is offline   Reply With Quote
Old 05-21-2015, 11:16 AM   #24
Did Emerson ever issue a final report? There was also a rumor of an unauthorized rust inhibitor coating change from suppliers of Copland compressor parts?
Old 05-21-2015, 11:51 AM   #25
I think there was, but I'd have to look.
Old 05-21-2015, 02:05 PM   #26
raylo32's Avatar
Rewards Points: 1,286
Yes, after some initial reluctance one of the locals sold me the R-410A TXV. The coil I had purchased online ~2007 from AC Overstock.com or such. The coils were readily available online then and not that $$. (like ~$300)
But I decided to not replace the R22 condenser just then so I pumped it down, installed the coil with the pre-installed R22 TXV, evacuated and brought it back up. Also checked subcooling and dialed in the charge. Still going strong 4 years on from coil replacement, 19 years total on condenser. <probably just jinxed myself>
Good luck, I hope you can find the parts you need.
Originally Posted by ashishm02 View Post
Hi Raylo,
Thanks,
John M.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 05-21-2015, 02:12 PM   #27
Rewards Points: 18
Oh wow, you kept the same compressor/condenser and had no issues? I was thinking if I can't get the R22 coil, I would buy a 410A coil and replace the TXV, but it just seems like a lot of work. Your way seems much easier
Old 05-21-2015, 02:20 PM   #28
raylo32's Avatar
My only problem was a small leak in the original coil. I was toying with the idea of upgrading to a new R-410 2 stage condenser while doing the work, but opted for the cheaper quick fix.
Old 05-21-2015, 03:17 PM   #29
An old Tradesmen
R410A does not break down seals or gaskets.
If you have a paper from any manufacturer stating it does. Post a copy of it.
Old 05-21-2015, 03:19 PM   #30
An old Tradesmen
Standard practice not to sell parts to home owners unless they we're installing the part also.
Struggling with Home warranty company over evap coil, plenum, etc, please advise! JYale HVAC 7 04-12-2011 04:49 PM
Damaged fins on furnace EVAP coil rlukas79 HVAC 5 12-21-2010 03:10 PM
Evap Coil Replacement Rickhoff HVAC 3 08-24-2009 09:58 PM
Evap coil question merlinfolks HVAC 15 07-27-2009 07:20 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
