Convert Portable AC To Mini Central AC. Any Reason Why This Would Not Work? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-31-2011, 04:29 PM   #16
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
I may do that, the through the wall could go in the bedroom and the existing in my office. I did install a dedicated 20 amp circuit for it so may as well use it. How well do those through the wall units work in winter? Are they well enough insulated and sealed so I wont have a massive heat loss?
Old 03-31-2011, 04:39 PM   #17
Rewards Points: 392
Originally Posted by Red Squirrel View Post
This will only cost about 200 bucks, some aluninium pipe, insulated flex pipe, misc hardware, the fan itself. vs $5,000 and for the 2 months of the year that I'll use it, I can't justify paying for central AC or a ductless split unit. Maybe in the future.
But if this won't work, then I might stick to just hauling the unit around. As for the cooling of the compressor, I modded the unit so it uses outside air hence the intake/exhaust pipes. I found this made a huge difference last year.
I bet you could get it to work. You might not have enough cooling capability, but I don't see why it wouldn't work. It just might be a hard thing to explain if the house burned down for another reason..
zootjeff is offline   Reply With Quote
Old 03-31-2011, 08:41 PM   #18
Rewards Points: 150
You NEED returns, and even if you did it is probably way undersized.
Dont bother.
The purpuse of Air Cond. is to REMOVE HEAT FROM AN AREA..... how will your rooms properly cool if there are no return air?
alecmcmahon is offline   Reply With Quote
Old 03-31-2011, 09:13 PM   #19
Wire Chewer
Rewards Points: 46
Dont bother.
Naturally two bodies of air will want to equalize, if they are able to. So if I depressurize the basement and pressurize the upstairs then naturally air will be pushed down through vents, cracks etc. Though, I have no furnace return in the basement, so to fix that I may actually add one right where the upstairs return is, so that would create a direct path. But TBH, I don't think the returns would be an issue. I installed an inline fan for my bathroom and when I close the bathroom door, I can feel air coming out of the furnace vent. In fact it makes the shower curtain move. Those inline blowers really do have quite a lot of balls.
The only issue is hot air rises, and I'll be trying to push it down, so that may possible pose a challenge. It was an idea, but I'll probably drop it.
DIY central air with water, would it work? Red Squirrel HVAC 15 05-24-2010 11:24 PM
Honeywell mini zone and generator power daddyrabbit HVAC 2 02-12-2010 11:09 PM
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 08:07 PM
hot water and central heating wont work independently khanay Plumbing 2 07-12-2008 04:14 PM
