Controls For Hot Blast Furnace? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-16-2012, 03:55 PM   #1
controls for hot blast furnace?
I recently purchased a house with a hot blast wood add on furnace. But the controls to run everything have been removed. What controls do I need to get this hooked up and running properly? The blower is there fort moving heat.and a automatic draft dampener on front.
bronco77 is offline   Reply With Quote
Old 10-16-2012, 04:08 PM   #2
Rewards Points: 14,306
Is there a model #, ser. # on the unit someplace that you can just Google?
Got a picture?
Old 10-16-2012, 04:15 PM   #3
It is a model 1600. And I see I can get a Honeywell limit switch for it. But I wasnt sure if I need some sort of circuit board to be able to hook limit switch, fan and draft, and thermostat into?
Old 10-16-2012, 05:33 PM   #4
Ok so finally found some more info. From what I under stand I need a fan center to control everything. Will any fan center work?
Also found a limit switch 100f off, 125f on, 200 high limit.does this all look correct?
Propane Furnace - Diminishing Gas Supply After Ignition edro HVAC 9 01-13-2012 04:24 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
